WTF!! oil in #2 spark plug? HELP!!
Old May 13, 2003 | 10:45 AM
hYpE-R-29's Avatar
Default WTF!! oil in #2 spark plug? HELP!!
just as the question states I have oil in the #2 spark plug and the plug is fully drenched...WTF is wrong?
Old May 13, 2003 | 11:04 AM
Big Phat R's Avatar
Default Re: WTF!! oil in #2 spark plug? HELP!! (hYpE-R-29)
do a leakdown test to check the rings
also check your valve seals
Old May 13, 2003 | 11:05 AM
.RJ's Avatar
.RJ
sounds like the valve cover gasket (or rather the little r ubber seals around the plug well) has given up. Cheap to replace, takes 10 minutes.
Old May 13, 2003 | 11:07 AM
JDM CTR '00's Avatar
Default Re: WTF!! oil in #2 spark plug? HELP!! (Big Phat R)
is the oil were the plug wire goes? If so your round gasket is jacked up just replace it
Old May 13, 2003 | 01:05 PM
Dave-ROR's Avatar
Default Re: WTF!! oil in #2 spark plug? HELP!! (ChargedSi99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChargedSi99 &raquo;</TD></TR><TR><TD CLASS="quote">is the oil were the plug wire goes? If so your round gasket is jacked up just replace it</TD></TR></TABLE>
what he said. (and RJ)
Old May 13, 2003 | 02:54 PM
hYpE-R-29's Avatar
looks like it the valve seal...thnx guys
Old May 13, 2003 | 04:48 PM
.RJ's Avatar
.RJ
They're cheap, like $2 each. Replace all 4 while the cover is off.
Old May 13, 2003 | 06:16 PM
SMZ GSR's Avatar
Default Re: WTF!! oil in #2 spark plug? HELP!! (.RJ)
just as .RJ and Charged99si said. i had the same problem once (only due to dealer not replacing the ring after changing my timing belt )
rjmancia
15
Sep 13, 2008 08:57 AM
VTEC_Du_Ma_Mai
Sep 6, 2008 11:08 AM
thegooddoctorceretti
Oct 11, 2007 02:50 PM
Saki
Mar 4, 2005 06:20 PM
vimsen
Nov 1, 2003 02:37 PM
