HONDATA and DSM 450cc's...what was the problem again?
Old May 13, 2003 | 09:08 AM
mamaboy's Avatar
Default HONDATA and DSM 450cc's...what was the problem again?
I've been searching for this topic on this board and hondata's website.....but what was the problem again with the DSM 450cc's.....or as brought to attention by hondata.....I have some 2G DSM 450cc's from my previous project and I'm planning to run that with a HONDATA and Intank in an EG
Old May 13, 2003 | 09:09 AM
Dee's Avatar
Dee
Default Re: HONDATA and DSM 450cc's...what was the problem again? (mamaboy)
If you want some RC 440's I'll sell you mine because I am upgrading to 720's.
Old May 13, 2003 | 10:29 AM
jabroni95gsr's Avatar
Default Re: HONDATA and DSM 450cc's...what was the problem again? (Dee)
There is no real problem. Just make sure you run the resistor box and get them cleaned/balanced before hand/
Old May 13, 2003 | 11:30 AM
RGAZ's Avatar
New User
There should be no problem, but if you happen to have hard starting when hot and major idle control problems, then there is slight chance it could be the way your hondata and your dsm's work with each other.
Sometimes they don't play well together.
I have never seen a problem though, others have and some haven't. So don't spread any rumors that they don't work together in all cases please!
Randy
Old May 13, 2003 | 12:50 PM
mamaboy's Avatar
92-95 EG D16Z6 motor / SI hatch are OBD1 it shouldn't need a resistor box since it already has one correct? Planning to run the APEXi kit with the 450cc's, intank, and hondata for fuel management......PWR intercooler from Mike again probably.....and i'm back..woot woot.....this is going to take about a year to get all the parts again....from wheels, suspension, exterior, and turbo setup.....
Old May 13, 2003 | 12:58 PM
turboex's Avatar
Dont call hondata on this issue. I delt with them along time ago, i talked to doug and he said they were fine. Now just a month back i had a problem wih the chip being bad and the tech guy at hondata told me that it was the dsm injectors and that you cant use them with hondata. I asked to speak to his boss or doug and none of them were around. I hope they fired his ***! He told me i did not know what i was doing and those injectors would never work, even though i had been running them with the same setup for 2 years and never had a problem and back in the day before he worked there doug had told me over the phone that they were fine to use. Dude those injectors will work fine, just make sure your resistance is correct, via resistors or what ever.
Old May 13, 2003 | 03:05 PM
mamaboy's Avatar
Default Re: HONDATA and DSM 450cc's...what was the problem again? (turboex)
thank god!....thanks for the post....I remember something about the resistance is different from injector to injector....but i'm sure this set will work....it's out of working 2G DSM
J . K .
Engine Management and Tuning
15
Sep 29, 2010 09:51 PM
fullblown
Oct 4, 2005 09:53 AM
Doodoo
Feb 27, 2003 07:45 AM
Sprockets
Dec 21, 2002 12:56 PM
SpeedMonkeyRacing
Apr 25, 2002 12:34 PM
