Test and Fit of my Turblow.. *Pics 56k warning*
Well, she is almost done I just need a some Charge pipes, DP pipe, and the oil drain flange for the turbo. It should be done by last week of May, I hope.. Lol
My turbo is a Garrett T25 with STD manifold and a custom made adapter plate. *Note*.. I found out that my front crossmember is hitting the inlet intake of the turbo. So what I did is I hammered the crossmember just enough to clear intake outlet so it wouldn't hit the crossmember. It came out pretty good, but I still need to hammer it one more time for more clearance... Other parts are:
T25 DP plate
1stG DSM BOV
1stG SMIC
HKS EGT gauge
Blitz racing boost gauge
450cc DSM injectors
SMC+ for fuel management
Aeroequip fittings and SS braided lines(return and feed line)
and the lil things lol
This was my last project that I did. It's a Y8 intake manifold swapped with Integra LS TB..
T25 DP plate
1stG DSM BOV
1stG SMIC
HKS EGT gauge
450cc DSM injectors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdaccord »</TD></TR><TR><TD CLASS="quote">any clearance with the rad issues? i am getting ready to do my own with the same turbo and manifold</TD></TR></TABLE>Well, mine fit perfectly no rad issues at all. It's because I took out the A/C fan and the compressor for more space. So yeah, no rad issues here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Flip »</TD></TR><TR><TD CLASS="quote">sweet setup cuz! can't wait to see this baby run
...you already have a challenger *danny's vw2.0-T, it should be a good match</TD></TR></TABLE>Thanks cuz.
Oh ohhhh, I already have a challenger. Lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AztecEJ »</TD></TR><TR><TD CLASS="quote">lookin good rj!
Less then a week and I'll finally have my setup on the car. Two turbo sohc's prowling the streets
</TD></TR></TABLE>Hehehehe, make sure when i get back from Ny your stuff will be haulin. LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CWBETB »</TD></TR><TR><TD CLASS="quote">Let the boost loose! Wooohwoooo!
Your going to love it! "If nothing blows up
"</TD></TR></TABLE>YOu know this.
i ve got just about everything done with mine except the oil line and finishing my plate, the first one hit the radiator, a few questions
1. i have the same bov, but i ran a vacumm frm the intake manifold , is this OK?
2. i dont have any of the oil fitting on the turbo, where can i get one? and what does it look like?
3.did u have a hard time getting the oil pressure switch off ?, cause im having a lot of trouble .
i have some pics up soon,
another thing u might want to find a local mitsi dealer that will give u an old exhaust from a defect, u could take the dp flange from it , thats what i did , dude said he had a whole bunch from a car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowman si »</TD></TR><TR><TD CLASS="quote">Damn man, moving right along with the project. Looks good
Sure is...he just upgraded the turbo to a 14b
</TD></TR></TABLE>Sure is...he just upgraded the turbo to a 14b
My friend has pretty much that exact same set up in his crx, without the y8 intake manifold. But he made 155hp/154tq to the wheels on 8 lbs with that set up.
I am doing almost the exact same thing as you. Except i am running a ZC, and i decided to use a larger turbo. I bought a tdo5h 14b turbo, cause the t25 was a little too small for my engine imo.
slowman
Feb 20, 2003 10:47 AM
Cant wait to see some vid of it!
