SS Brake line install
Old May 12, 2003 | 07:25 PM
Que_Lude's Avatar
Default SS Brake line install
Is it easier to drain out all of the brake fluid from the car, install the lines and then refill the master cyl? The NTPOG write-up just lets the brake fluid drip out of the lines...
Old May 12, 2003 | 07:38 PM
Elkins911's Avatar
Default Re: SS Brake line install (Que_Lude)
let the fluid drop out the line. if you drain everything, then you need to bleed the system. when your changing out the lines, make sure the master cylinder is always full.
Old May 12, 2003 | 08:05 PM
bb6h22a's Avatar
Install the lines with the MC full, you're gonna bleed afterward anyway. Draining the system will just add more time to the install, and not benefit you.
Old May 12, 2003 | 08:17 PM
Honda318dx's Avatar
Default Re: SS Brake line install (bb6h22a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb6h22a &raquo;</TD></TR><TR><TD CLASS="quote">Install the lines with the MC full, you're gonna bleed afterward anyway. Draining the system will just add more time to the install, and not benefit you.</TD></TR></TABLE>
yeap and your MC doesn't like to go "dry" seals will get eaten
Old May 12, 2003 | 08:50 PM
kotetu's Avatar
where did you buy the SS lines and how much were they?
Old May 12, 2003 | 09:33 PM
Que_Lude's Avatar
Default Re: SS Brake line install (kotetu)
http://www.opmmotorsports.com/....html
Lots of good 4th gen stuff here... X-mas early if you got the bucks......
I'm going to get the Motive positive pressure bleeder and was thinking of blasting all of the brake fluid out after taking off the OEM lines. And then refilling the MC w/fresh fluid. Just was thinking that it would be easy with the positive pressure unit.
I'll leave the old fluid in the MC.... Thanks guys
Old May 12, 2003 | 11:29 PM
TimeRacer's Avatar
You don't want to blast out all the old fluid and replace it with air. A lot of the times the ABS unit LOVES to keep air in the system and it takes literally weeks to get all the air out. If you have had the dealer do the brake fluid changes you'll KNOW when the new fluid is though since it'll change from a murky brown to the new clear brake fluid.
Old May 13, 2003 | 04:46 AM
desmat's Avatar
Guys,
I don't write this to make money or to promote a shop but i tought you might be interested : Our Club is doing a group buy on SS brake lines. It's 100$ CANADIAN for the front ones or 175$ CANADIAN for front & rear.
Check out our french thread here if you want :
http://montrealpreludeclub.com...=4098
Blaast is the guy to talk to...
Old May 13, 2003 | 11:31 AM
kotetu's Avatar
Default Re: (desmat)
Looks like they are for both 4th and 5th gen. I have a few questions for you desmat:
1) is the price of $175CAN ($125US) including shipping?
2) are these street use versions? (I have seen offroad only versions)
3) Does the seller have some way to prove he's a "good seller" ?
4) is there any problem with shipping them to California?
Thanks!
Old May 13, 2003 | 12:19 PM
desmat's Avatar
Default Re: (kotetu)
For shipping I suggest you contact the seller. He's a friend of mine and he's a good seller. You can check out his ebay power seller profile here
http://cgi2.ebay.com/ebaymotor...feron
and he his a verified seller on paypal. They are for street use.
Good luck
Old May 13, 2003 | 12:37 PM
kotetu's Avatar
Thanks, I emailed him. It's dnuferon@hotmail.com right ?
Bradstard
Oct 30, 2005 08:10 PM
youngvedder
Mar 17, 2004 10:31 AM
Que_Lude
May 13, 2003 07:36 AM
Milano97
Jan 14, 2003 11:36 AM
lePetitePrince
Nov 6, 2002 02:33 PM
