getto gasket leak
Old May 12, 2003 | 05:42 PM
andlude's Avatar
Default getto gasket leak
well my oil pan is leakin and its pissin me off and to change the gasket it looks like i might have to move a lot of **** maybe even raise my engine, but anyways what do u guys think if i just took some liquid gasket and rubbed it on the outside of the seals so i dont have to take apart everything?! let me know thanks
Old May 12, 2003 | 05:49 PM
Behan's Avatar
Default Re: getto gasket leak (andlude)
if you can't/don't want to do something correctly pay someone else to do it for you. yeah putting rtv or whatever might work, but for how long and do you really want to trust your engines oil to some rtv rubbed around the oil pan?
Old May 12, 2003 | 05:54 PM
Elkins911's Avatar
Default Re: getto gasket leak (93preludevtec)
the pan isnt hard to do. you dont need to raise the motor at all. just remove the cross member, remove the oil pan, replace the gasket, and re-install. if you decide to do it... ill try to walk you through.
Old May 12, 2003 | 05:57 PM
Hondaaccordvtec's Avatar
Default Re: getto gasket leak (Elkins911)
Don't forget about the downpipe - that needs to be removed as well.
Yuta
Nov 6, 2015 06:06 AM
StreetRacinThug
Dec 21, 2006 08:44 AM
ringgold
18
Sep 20, 2004 04:28 AM
FUP23
12
Mar 25, 2003 07:01 AM
yellowbulbs
Jul 17, 2001 01:12 PM
