Dyno plot help with Toda C's
Anyone wana give some advice thoughts on this dyno plot. Its my roomates setup in his 2k itr
Mods are as follows.
b18c5
12:1 compression je pistons
i beleive eagle rods
Toda valve train
Toda C's
Skunk2 cam gear seat at 0 for tunning
Toda Header
Ported and polished head/intake manifold and tbody at 67mm
2.5 exhuast no cat
Hondata stage 2
Rc 440 injectors
Aem fuel rail
stock fuel presure
Best run was 202 with an hour of dyno tuning
running 93 octane
No cam gerar tunning
Idles pretty good at 1k.
b18c5
Toda valve train
Toda C's
Toda Header
2.5 exhuast no cat
Hondata stage 2
Rc 440 injectors
Aem fuel rail
stock fuel presure
running 93 octane
Tuning gears is the first thing I would look into. Personally, I wouldn't bother changing out the injectors, just play w/ the fpr.
270cc with spec c's? nah.
no need to swap out injectors. with hondata, 440cc is just fine for spec c's.
sgt use to run 60-70psi fuel pressure with 310cc's in his itr with spec c's.
tune the cam gears.
tune the cam gears.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotrb18c1 »</TD></TR><TR><TD CLASS="quote">I think his Injectors are to big..440cc thats big for what he has...I think it would run good with 270cc...Thats all he needs no bigger..
Ross</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweety R »</TD></TR><TR><TD CLASS="quote">Smaller injectors.
Adjust fuel pressure.
Set for better timing advance.
Tune cam gears.
Good for a lil more than 7 extra ponies.</TD></TR></TABLE>
you guys have absolutely no clue what you are talking about.
First off a 270 will be waaay too small
Second, it doesnt matter if the injectors are too big b/c they can be regulated with his hondata.
Tune cam gears.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR-01 »</TD></TR><TR><TD CLASS="quote">proper tuning power should be at 215-220
not likely
</TD></TR></TABLE>not likely
BustaNutt-616...I know for a fact that 270cc injectors are not to small for his set up..Trust me you dont want me to prove it to you...
And if you know so much why dont you tell him what he needs to do to get more HP out of his set up.....
Ross
Ross
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotrb18c1 »</TD></TR><TR><TD CLASS="quote"> BustaNutt-616...I know for a fact that 270cc injectors are not to small for his set up..Trust me you dont want me to prove it to you...
270 would barely be enough.
The rule of thumb with fuel is budget 20% more fuel than you need for your
desired power output. In this case 310 or 370 would be ideal.
Since hehas not tuned his cams yet, i think thatwould bethe next logical course of action.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BustaNutt-616 »</TD></TR><TR><TD CLASS="quote">
[b]you guys have absolutely no clue what you are talking about.[b]
.</TD></TR></TABLE>
I agree, there seems to be so much mis-information floating around these days. People, if you don't know what the hell you are talking about please chill and have a nice can of STFU.
I don't think that I have ever been as frazzled as when people give advice when they know nothing about a subject!
.</TD></TR></TABLE>
not bad for the mods and power, but i think those fuel system upgrades don't give u that much power compare to the money u paid. Go fast, then go with ITB and build bottom run with some serious compression there
I STRONGLY AGREE WITH HIM!!!
can't read the chart clearly but looks like fuel pressure is crapping out past 7500, did you at least upgrade your fuel pump ?
nice power, I'd personally go with 270cc injectors and 60-65 psi fuel pressure for better atomization ... but thats just me
greg
greg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEETAH »</TD></TR><TR><TD CLASS="quote">can't read the chart clearly but looks like fuel pressure is crapping out past 7500, did you at least upgrade your fuel pump ?
greg</TD></TR></TABLE>
Greg...for a bigger version of the plot copy and paste this link into your browser http://www.imagestation.com/pi...g.jpg
Austin
p.s. RC 440cc/min have better atomization than the RC 310, or 370's per RC Engineering, not sure about the 270's, or the 290's
Austin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr »</TD></TR><TR><TD CLASS="quote">for the love of god tune the gears..............</TD></TR></TABLE>
and add 440's @ 80psi...
To know where Vtec should come on, You take your car to a Dyno and right before you turn the car on unplug the vtec solenoid and do a pull up to 6500 rpms and where TQ starts to drop is where you should turn Vtec on...
I have Skunk2 stage 3 cams and my vtec comes on at 5700 rpms...
And i dont have a vafc.
Thanks
Ross
Thanks
Ross
lol.. I agree with Canuck.. That's why I sit back and listen to the experts..
