Dyno plot help with Toda C's
Old May 12, 2003 | 05:30 PM
90accord1's Avatar
Default Dyno plot help with Toda C's
Anyone wana give some advice thoughts on this dyno plot. Its my roomates setup in his 2k itr
Mods are as follows.
b18c5
12:1 compression je pistons
i beleive eagle rods
Toda valve train
Toda C's
Skunk2 cam gear seat at 0 for tunning
Toda Header
Ported and polished head/intake manifold and tbody at 67mm
2.5 exhuast no cat
Hondata stage 2
Rc 440 injectors
Aem fuel rail
stock fuel presure
Best run was 202 with an hour of dyno tuning
running 93 octane
No cam gerar tunning
Idles pretty good at 1k.
Old May 12, 2003 | 05:40 PM
InevitableRace's Avatar
Default Re: Dyno plot help with Toda C's (90accord1)
I think his Injectors are to big..440cc thats big for what he has...I think it would run good with 270cc...Thats all he needs no bigger..
Ross
Old May 12, 2003 | 05:48 PM
Eric R's Avatar
Smaller injectors.
Adjust fuel pressure.
Set for better timing advance.
Tune cam gears.
Good for a lil more than 7 extra ponies.
Old May 12, 2003 | 06:08 PM
NSX Bob's Avatar
New User
Default Re: Dyno plot help with Toda C's (Tweety R)
Tuning gears is the first thing I would look into. Personally, I wouldn't bother changing out the injectors, just play w/ the fpr.
Old May 12, 2003 | 06:11 PM
snake01's Avatar
that car should be capable of 210-220 at the wheels that's just the thing with toda C's hours of dyno time.
Old May 12, 2003 | 07:01 PM
canuck-mx6's Avatar
Hondata can handle 440 CC injector just fine, there is no need to swap out the injectors
Old May 12, 2003 | 07:14 PM
woodog's Avatar
Default Re: Dyno plot help with Toda C's (allmotrb18c1)
270cc with spec c's? nah.
no need to swap out injectors. with hondata, 440cc is just fine for spec c's.
sgt use to run 60-70psi fuel pressure with 310cc's in his itr with spec c's.
tune the cam gears.
Old May 12, 2003 | 08:38 PM
ITR-01's Avatar
Default Re: Dyno plot help with Toda C's (dc2R320)
proper tuning power should be at 215-220
Old May 12, 2003 | 08:59 PM
seanb18c1's Avatar
Where's your v-tec set at?
good top end torque
Old May 12, 2003 | 09:08 PM
MackSpeed-616's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotrb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">I think his Injectors are to big..440cc thats big for what he has...I think it would run good with 270cc...Thats all he needs no bigger..
Ross</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweety R &raquo;</TD></TR><TR><TD CLASS="quote">Smaller injectors.
Tune cam gears.
Good for a lil more than 7 extra ponies.</TD></TR></TABLE>
you guys have absolutely no clue what you are talking about.
First off a 270 will be waaay too small
Second, it doesnt matter if the injectors are too big b/c they can be regulated with his hondata.
Old May 12, 2003 | 09:10 PM
Default Re: Dyno plot help with Toda C's (ITR-01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR-01 &raquo;</TD></TR><TR><TD CLASS="quote">proper tuning power should be at 215-220 </TD></TR></TABLE>
not likely
Old May 12, 2003 | 09:19 PM
Default Re: Dyno plot help with Toda C's (BustaNutt-616)
BustaNutt-616...I know for a fact that 270cc injectors are not to small for his set up..Trust me you dont want me to prove it to you...
And if you know so much why dont you tell him what he needs to do to get more HP out of his set up.....
Ross
Old May 12, 2003 | 10:08 PM
sgT's Avatar
sgT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotrb18c1 &raquo;</TD></TR><TR><TD CLASS="quote"> BustaNutt-616...I know for a fact that 270cc injectors are not to small for his set up..Trust me you dont want me to prove it to you...
270 would barely be enough.
The rule of thumb with fuel is budget 20% more fuel than you need for your
desired power output. In this case 310 or 370 would be ideal.
Since hehas not tuned his cams yet, i think thatwould bethe next logical course of action.
Old May 13, 2003 | 04:08 AM
canuck-mx6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BustaNutt-616 &raquo;</TD></TR><TR><TD CLASS="quote">
[b]you guys have absolutely no clue what you are talking about.[b]
.</TD></TR></TABLE>
I agree, there seems to be so much mis-information floating around these days. People, if you don't know what the hell you are talking about please chill and have a nice can of STFU.
I don't think that I have ever been as frazzled as when people give advice when they know nothing about a subject!
Old May 13, 2003 | 04:12 AM
YelLowITR's Avatar
not bad for the mods and power, but i think those fuel system upgrades don't give u that much power compare to the money u paid. Go fast, then go with ITB and build bottom run with some serious compression there
Old May 13, 2003 | 06:50 AM
Drag R's Avatar
I STRONGLY AGREE WITH HIM!!!
Old May 13, 2003 | 07:12 AM
Suprdave's Avatar
Default Re: Dyno plot help with Toda C's (Drag R)
No way that thing is making 220whp...210Max
Suprdave
Old May 13, 2003 | 07:37 AM
B18CXr's Avatar
for the love of god tune the gears..............
Old May 13, 2003 | 07:56 AM
CHEETAH's Avatar
can't read the chart clearly but looks like fuel pressure is crapping out past 7500, did you at least upgrade your fuel pump ?
nice power, I'd personally go with 270cc injectors and 60-65 psi fuel pressure for better atomization ... but thats just me
greg
Old May 13, 2003 | 08:01 AM
RTW DC2R's Avatar
Default Re: Dyno plot help with Toda C's (CHEETAH)
what everyone else said...gears and fuel tuning is a must
Modified by RTW DC2 at 1:33 PM 5/13/2003
Old May 13, 2003 | 08:06 AM
Austin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEETAH &raquo;</TD></TR><TR><TD CLASS="quote">can't read the chart clearly but looks like fuel pressure is crapping out past 7500, did you at least upgrade your fuel pump ?
greg</TD></TR></TABLE>
Greg...for a bigger version of the plot copy and paste this link into your browser http://www.imagestation.com/pi...g.jpg
Austin
p.s. RC 440cc/min have better atomization than the RC 310, or 370's per RC Engineering, not sure about the 270's, or the 290's
Old May 13, 2003 | 08:41 AM
Willard's Avatar
Default Re: Dyno plot help with Toda C's (B18CXr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">for the love of god tune the gears..............</TD></TR></TABLE>
and add 440's @ 80psi...
Old May 13, 2003 | 12:44 PM
Meat_Wagon's Avatar
Default Re: Dyno plot help with Toda C's (Willard)
i believe that vtec is set at 5900. I was thinking it should be at 6500-6800. Anybody have any insight at what is the ideal range.
thanks
Old May 13, 2003 | 01:10 PM
Default Re: Dyno plot help with Toda C's (Meat_Wagon)
To know where Vtec should come on, You take your car to a Dyno and right before you turn the car on unplug the vtec solenoid and do a pull up to 6500 rpms and where TQ starts to drop is where you should turn Vtec on...
I have Skunk2 stage 3 cams and my vtec comes on at 5700 rpms...
And i dont have a vafc.
Thanks
Ross
Old May 13, 2003 | 03:19 PM
00MRSi's Avatar
lol.. I agree with Canuck.. That's why I sit back and listen to the experts..
