Ground Control Install
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gravity »</TD></TR><TR><TD CLASS="quote">So i got a new set of ground controls coil over sleeves.
Just wonder if the install is as simple as regular spring installs.
anything i should watch for .</TD></TR></TABLE>
To me its easier than a normal spring install. The springs are shorter with a coilover setup, so its a lot easier to compress the shock and springs to reinstall them on the car.
If you've installed "other" types of springs, this should be really easy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redx »</TD></TR><TR><TD CLASS="quote">cut it in half...rip the rubber off the boot nd leave the metal...read the instructions
i did read them. i was just asking a question.
</TD></TR></TABLE>i did read them. i was just asking a question.
