AEM EMS user...can you use 1 02 instead of 2? (00 gsr)
I'm thinking about taking out my 2nd o2 to replace it w/ my TE wideband sensor. However, I dunno if AEM EMS eliminates the 2nd o2 or I have to weld another bung just for the 5 wire o2..
Jeff-
Jeff-
You don't need any of the stock O2 sensors to run AEM EMS..
If you install a wideband, put it in the stock O2 sensor bung #1... you want
a reading before your catalytic. From the output of your WB O2 controller,
you need to tap into the #1 o2 sensor pin in the harness to the EMS. You should
also provide the ground.. some people do this, some don't..
11psiTurboSI
May 24, 2005 02:22 PM
