DB PGM-FI fuel injector relay?
Old May 12, 2003 | 11:09 AM
evolve's Avatar
Default DB PGM-FI fuel injector relay?
Where is it?
In the Haynes is shows to be under the gauge cluster between the steer column and the left side of the chassis. But I can't find it. I was wondering if that picture only shows 92-93 models? It's nowhere to be found in the specified area. I need to disconnect it for a compression test. What's an alternative? Disconnect the fuel pump from under the rear seat?
Old May 12, 2003 | 12:13 PM
JimBlake's Avatar
Default Re: DB PGM-FI fuel injector relay? (evolve)
Don't have a picture of the relay, but... For a compression test, the idea is to avoid gasoline & spark. You can unplug the wiring harness from the 4 injectors, you really don't care that gas is being pumped thru the rail. Unplug your distributor to prevent spark. The relay or whatever else is is better because the injector wires are probably brittle from heat & age.
01integra_gsr
Dec 10, 2011 11:08 AM
njmad
Mar 25, 2010 05:35 PM
CivCruise
Oct 10, 2009 08:33 PM
pdiggitydogg
62
Nov 10, 2007 01:28 PM
SiBuddy00
Jul 13, 2005 08:15 PM
