problem with my tach
If it just started happening the worst that it could be is that its either something with your tach or its a bad ignintor.
If you worked on you car and it started happening its most likely that the ground wire that attaches to the thermostat water neck is off or loose....
Adi
Adi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted97Lude »</TD></TR><TR><TD CLASS="quote">the LS tach in my Teggi keeps jumpind around like crazy, i had the distributer off the other day, and it started after i out it back on, so, what did i do to it, how can i fix it?</TD></TR></TABLE>
i have the same problem, except mine only happens when im at WOT, it jumps up only, not down. except i was not messing around with anything in the engine, it just started happening one day. i would like to know the answer to this too.
