Anyone running a b-series motor with a t3 turbo?
Old May 12, 2003 | 05:36 AM
jeekE_'s Avatar
Default Anyone running a b-series motor with a t3 turbo?
I will be boosting a gsr motor this summer, and i was thinking of using a t3 turbo because of its quick spool and because i auto-x. I was wondering what manifolds people are using with this setup because i know the most t3 turbos are internally wastegated. Any info is greatly appreciated.
TIA,
marek
Old May 12, 2003 | 08:56 AM
scooter's Avatar
Default Re: Anyone running a b-series motor with a t3 turbo? (jeekE_)
I am using a T3 off a Chrysler LeBaron. It spools very quick. I am using a SFP manifold and a external Wastegate.
scott
Old May 12, 2003 | 09:05 AM
Joseph Davis's Avatar
Default Re: Anyone running a b-series motor with a t3 turbo? (scooter)
If you want a moderate bump in power, mainly low down and midrange gains, then any T3 will do you fine.
If it were my GS-R, I'd find the .60 trim T3 off 84-86 Ford 2.3 or 84-87 300ZX for a decent street car turbo. It'll feed a little more power up high so you get the big power VTEC spike instead of falling flat on your face at anything over ~7-8 psi in the upper revs. Try for a .63 AR turbine (manual Ford 2.3T and all 1G 300ZX), because a little peakiness will actually suit the B18C1.
The kids with the T3/4's have something going for them, too. You might consider talking to slowcheapturbo about something that will put out power where you want it, and run lower boost for autocross, and then you can turn up the boost and make some nice power for other purposes.
Old May 12, 2003 | 09:58 AM
TurboSedan's Avatar
New User
You can get the Max Rev manifold without the external wastegate flange. I recommend it if you wish to retain A/C. If you don't care, you might want to hit up Tinker219 for a custom-lovefab manifold. He does some nice work.
Old May 12, 2003 | 10:26 AM
jeekE_'s Avatar
Default Re: Anyone running a b-series motor with a t3 turbo? (J. Davis)
how quickly does a t3\t04e spool up compared to just a t3? Because i was also considering a garrett t3\t04e 57 trim with a 63 A/R. I just didnt want it to dog on the track. with a t3\t04e what would be the optimum boost for track? what would optimum boost be for the street. I dont drag, so boosting double digits is not that important.
tia
Old May 12, 2003 | 10:42 AM
SI_DRIVR's Avatar
When putting my T3 with an internal wastegate on my b-series engine. I actually oppted for the external manifold. The internal required me to remove A/C. Only reason I switched from internal to external
96romaEK
May 11, 2010 08:01 PM
turbosol_16
Dec 27, 2006 06:41 AM
big-cat
May 11, 2006 10:30 AM
nofatchicks
Mar 18, 2004 04:32 PM
SiRkid
Oct 9, 2002 11:19 AM
