Hondata w/ 3rd gen prelude?
If you want to use a Hondata system, you will have to convert the car to OBD1 with an OBD1 distributor, then use a pr4, p74 or p75 ecu. As long as the car is manual you can then use either an s100 or s200 system with the options you want or need.
The problem withthe engine you mentioned is that it has nowhere near the same potential as the more modern b-series engines. It has a weird bore and stroke. Displacement (cc): 1958
Power (bhp@rpm): 135@5800
Torque (ft/lbs@rpm): 111@4000
Compression Ratio: 9.0:1
Bore (mm): 81
Stroke (mm): 95
Bore (mm): 81
Stroke (mm): 95
93delslow315
May 27, 2010 09:23 PM
