HELP, fuel concentration problem!
Old May 11, 2003 | 07:38 PM
awps's Avatar
Default HELP, fuel concentration problem!
i have a 97 integra gsr with a drag gen 3 turbo. it has a crane ignition and a fields vtec/fuel controller also (i leave the fields turned off though). i am having a problem with the car when it goes over a large bump, or gets jolted hard. the fuel concentration seems to be getting out of whack. before the car his a bump it runs fine and the a/f guages goes from lean to rich, up and down, like it should. after it hits the bump it stays at rich when i have my foot on the gas, and as soon as i take it off a little it goes to stoich, there is no inbetween. the car also backfires alot when its like this. if i turn the car off then turn it back on everything goes back to normal. i was thinking maybe it was a sensor or some loose wiring but im not sure. how would i go about finding what the problem is? thanks.
Old May 12, 2003 | 07:27 AM
awps's Avatar
Default Re: HELP, fuel concentration problem! (awps)
by the way, i get error code 3 and 23, MAP sensor and knock sensor, but i just replaced the map sensor with a brand new one. ;\
Old May 12, 2003 | 04:35 PM
awps's Avatar
anyone?
Old May 13, 2003 | 07:13 AM
awps's Avatar
bump
vtec25
May 15, 2006 02:07 AM
ScandalousCivic
May 10, 2005 06:20 PM
iowarex72
May 27, 2004 02:22 PM
Spudddy
May 10, 2003 06:17 AM
