b18c block with b16a2 head....any good?
Old May 11, 2003 | 07:35 PM
B_1_8_hatch's Avatar
Default b18c block with b16a2 head....any good?
stock b18c block with a b16a2 head and possibly a b16a2 tranny, will that be an okay set up to put into an eg hatch?
would it run good with the b16 head and tranny?
or should i just find a full gsr swap?
Old May 11, 2003 | 09:55 PM
Moto TO4ELSVTEC's Avatar
Default Re: b18c block with b16a2 head....any good? (93hb)
Yes
Yes
Depends on do you want low end torque of b18a block with advantage
of vtec power or do you want a no frills swap-then go gsr.
Old May 12, 2003 | 02:55 PM
Default Re: b18c block with b16a2 head....any good? (Moto TO4ELSVTEC)
so the gsr motor with a b16 head is better than a gsr motor with a gsr head?
Old May 12, 2003 | 03:00 PM
Havokmkr's Avatar
Check out c-speedracing.com They have a compression tester.
Old May 12, 2003 | 03:30 PM
JunIntegra's Avatar
Default Re: b18c block with b16a2 head....any good? (Havokmkr)
the b16 heade will lower the compression due to its larger combustion area. the gr head has tha smallest therefor will give yu th best compression.(stock 10:1)
Old May 12, 2003 | 03:36 PM
so will it be a good motor to run in my eg hatch?
or
should i just spray a 65 shot in my ls motor?
Old May 12, 2003 | 03:48 PM
JunIntegra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hb &raquo;</TD></TR><TR><TD CLASS="quote">so will it be a good motor to run in my eg hatch?
or
should i just spray a 65 shot in my ls motor?</TD></TR></TABLE>
its a great motor for the hatch. i have an integra gsr and with Jdm headers, intake and catback, the thing goes! now throw in cams, higher compression, Intake manifold,etc, youll be screwin with that motor in a eg hatch!
my opinion on nos, dont even bother. not worth ****
Old May 12, 2003 | 04:04 PM
Default Re: b18c block with b16a2 head....any good? (JunIntegra)
so it will still be good even though it has a b16 head with the b16 intake mani on it instead of the gsr head and gsr intake mani?
thats the only thing i'm really wondering about. running this in my hatch should put me in the 14's correct?
Old May 12, 2003 | 07:52 PM
hatch_attack's Avatar
make sure you have some better pistons in it because your compression will be at like 9.8 to 1. im gonna run this same set up and im gonna use some b16 pr3 pistons which should bump it up to the 11.4 to 1 region i think...and yea the b16 head should work fine. its pretty much like a type r set up except for the internals. but get rid of the stock intake mani and get a skunk 2 or a type r one.
Old May 12, 2003 | 07:55 PM
pistons are still the stock gsr pistons.
Old May 12, 2003 | 08:02 PM
you should still run pretty quick with the stock gsr pistons because its not that big of a compression loss...and that b16 tranny should help too...i say go for it and then just build from there
Old May 12, 2003 | 08:13 PM
dc4drewH's Avatar
Default Re: b18c block with b16a2 head....any good? (theswarm)
I think I would leave the heads alone and just swap out the trannys unless you plan out going turbo the swap out the heads but with that tranny I hope you don't do a lot of highway driving
Old May 12, 2003 | 08:22 PM
Default Re: b18c block with b16a2 head....any good? (dc4drewH)
i don't do a lot of highway driving, my civic is just for the weekends. i have my daily driver that i use for everything else.
i pretty much have no choice on the head. the b16 head is what is on the gsr motor and thats what it will come with if i get this swap.
i'm just hoping i'm going to be pretty quick with the b16 head on it.
isn't the b16 tranny better than the gsr tranny?
Old May 13, 2003 | 05:09 PM
shorter gears...
Old May 13, 2003 | 05:19 PM
gumbybum's Avatar
put some ctr piston on there and that will bunp the compression back up
Old May 13, 2003 | 05:24 PM
so should i trade my b18b1 motor for this b18c with b16 head?
Old May 13, 2003 | 10:17 PM
gumbybum's Avatar
i would if it is in good condition, i hate my b18b though
Old May 14, 2003 | 07:45 AM
Default Re: b18c block with b16a2 head....any good? (gumbybum)
is it just a straight trade? if so, yea
Old May 14, 2003 | 08:15 PM
well, i have my ls motor sold and my ls jrsc sold, with that money, i will be able to get this gsr motor with b16 head and still have like 400 left over.
what do you think?
Old May 15, 2003 | 04:57 AM
Hate's Avatar
b18c1 block and b16 head = poor mans ITR. been looking into theese. it ia a good engine set up with a ported head. throw in a CTR intake cam and a itr exaust cam and youll have a good set up.
Old May 15, 2003 | 06:57 PM
Default Re: b18c block with b16a2 head....any good? (Hate)
i say go for it man
Old May 15, 2003 | 07:23 PM
turbob18a1's Avatar
get a clue if your gonna drag nitrous is the perfect replacement for the lack of displacement. but hey ..all slow pokes have their own opinion...
Old May 15, 2003 | 07:24 PM
turbob18a1's Avatar
_______
turbob18a1's Avatar
that last post was an error....
Unsought Devil
10
Nov 23, 2006 10:21 AM
Ruben19
Feb 22, 2006 06:29 AM
Project_EK
Oct 27, 2005 10:36 AM
JspecCivic94
Oct 25, 2005 06:26 AM
StRoKeD-B16bEj2
Oct 7, 2005 08:35 AM
