B16A vs B18C?
Old May 11, 2003 | 07:19 PM
SiR2's Avatar
Default B16A vs B18C?
which head is stronger? and which head has more flow? people are saying the b16a head is better. what do you guys think?
Old May 11, 2003 | 07:32 PM
RyanEJ8's Avatar
Default Re: B16A vs B18C? (SiR2)
They both flow almost the same. The B18C head flows slightly better at valve lift that is higher than any daily driver will see. There are flow charts on the Alaniz website.
Old May 11, 2003 | 07:34 PM
SiR2's Avatar
Default Re: B16A vs B18C? (RyanCivic2000)
thanks. i'll check it out. do you know of any other sources?
Old May 11, 2003 | 07:37 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR2 &raquo;</TD></TR><TR><TD CLASS="quote">which head is stronger? and which head has more flow? people are saying the b16a head is better. what do you guys think?</TD></TR></TABLE>
welcome newb.
which head is stronger? they're both the essentially the same, minus a few minor differences. From my personal experience w/either heads, the ITR/B16A (PR3) head flows better top end wise whereas the P72/GSR head has better low-mid range power but can lack top end power. I speak in terms of stock heads using stock intake manifolds. You can build either head up to make more power of course.
Outta the box though, a P72/B18C head will make more compression over a PR3/B16A/ITR head.
Old May 11, 2003 | 10:23 PM
SimbaDogg's Avatar
Default Re: B16A vs B18C? (Katman)
the b16 top end flows better than the b18c (head, including intake manifold) due to the dual stage intake manifold and butterflies, but the head themselves are about even
Old May 11, 2003 | 10:45 PM
EF-9SiR's Avatar
Default Re: B16A vs B18C? (DAFeLUNG)
so should someone spend the extra $600 to $800 to get the b18 as opposed to the b16?
Old May 12, 2003 | 12:08 AM
Katman's Avatar
Default Re: B16A vs B18C? (EF-9SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF-9SiR &raquo;</TD></TR><TR><TD CLASS="quote">so should someone spend the extra $600 to $800 to get the b18 as opposed to the b16?</TD></TR></TABLE>
depends if you want more torque or not
egfong
May 3, 2008 07:56 PM
Drizzo
Feb 19, 2004 10:57 AM
CRXEE8
20
Dec 6, 2003 11:29 AM
gamakichi77
Sep 22, 2003 09:40 PM
SuPeR_MaN
12
Sep 14, 2002 06:19 PM
