new to the board...need advice!
When using the AC on my integra, it begins to leak coolant from the bottom. Is this normal on your integras. I'm just worried because my car is brand new. Thanks in advance for your help.
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Is it green or colored? If not then it's probably condensation like it was mentioned earlier. The A/C lines aren't filled with coolant. So if you actually see coolant it may be a loose coolant line somewhere and should be fixed for free by the dealer.
dmemenza
Nov 25, 2017 04:15 AM
EnKidu
Nov 12, 2004 08:34 PM
