oil leak from filter mount on block?
Old May 11, 2003 | 02:10 PM
magic hat #9's Avatar
Default oil leak from filter mount on block?
my car has already burned oil, but now i think it's actually a leak. is it possible for the filter mounting point on the block to be warped? i've always used honda filters and i tighten them about 1/4 turn past hand tight with a filter wrench. i just put on a header and there was a drip of oil on the filter; there is never spots of oil where i park, but i assume it's because oil only leaks when the car is on. my car generally has a faint smell of burnt oil after hard driving; oil leaking from the filter would drip directly onto the header.
Old May 11, 2003 | 02:29 PM
B_CRUZ!'s Avatar
Default Re: oil leak from filter mount on block? (magic hat #9)
check to make sure that the old oil filter gasket is completely off.
Old May 11, 2003 | 02:32 PM
TypeR 599's Avatar
my friend is having a mysterious oil leak on his integra too. do you have aftermarket cams? maybe the cam seals are leaking. it could also be a leaky head gasket too. btw, when you put on the new oil filter, it should only be hand tightened. that would be enough
Old May 11, 2003 | 03:36 PM
nfn15037's Avatar
Default Re: oil leak from filter mount on block? (TypeR 599)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 599 &raquo;</TD></TR><TR><TD CLASS="quote">my friend is having a mysterious oil leak on his integra too. do you have aftermarket cams? maybe the cam seals are leaking. it could also be a leaky head gasket too. btw, when you put on the new oil filter, it should only be hand tightened. that would be enough</TD></TR></TABLE>
Aftermarket cams dont really have anyting to do with leaky cam seals....i have stock cams and they leak like a mother(125k miles!). Def. check the filter mating surface for old gaskets and/or crud. Best bet is to clean the entire motor thoroughly, thet way you can spot any fresh oil leaks.
Old May 11, 2003 | 06:35 PM
nope, no errant filter gasket and i don't believe the valve cover is leaking. i'll do a bit more research, but this seems like an odd place to leak.
Old May 11, 2003 | 06:40 PM
NSX Bob's Avatar
New User
If it's not from the old gasket (or pieces of the old gasket being stuck to the block) or from misthreading the filter, this seems a little odd. Oil dripping on the header certainly does have a distinctive smell though.
Old May 11, 2003 | 08:36 PM
B2FiNiTY's Avatar
Best thing to do is to totally wipe down all oil you see.
Start up the car while lifted and check to see where it's coming from.
Old May 12, 2003 | 07:54 AM
Haunt's Avatar
Not trying to make you sound stupid...but you are lubing the seal on the filter before putting it on right??
Old May 12, 2003 | 08:05 AM
Default Re: oil leak from filter mount on block? (Haunt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haunt &raquo;</TD></TR><TR><TD CLASS="quote">Not trying to make you sound stupid...but you are lubing the seal on the filter before putting it on right?? </TD></TR></TABLE>
yep.
i'm doing a valve adjustment in 4k miles. i will clean the motor and look for oil afterwards. the car has always lost oil so it's burned/leaked since purchase.
Old Aug 1, 2003 | 10:12 AM
STOLEN - ITR 98-0652's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magic hat #9 &raquo;</TD></TR><TR><TD CLASS="quote">i tighten them about 1/4 turn past hand tight with a filter wrench.</TD></TR></TABLE>
There's your problem... it's supposed to be 7/8 past... that's why there's numbers on them.
Old Aug 1, 2003 | 02:59 PM
BoBo Racing's Avatar
Default Re: oil leak from filter mount on block? (b.cruz)
u probably have a double gasket change the oil agiain real soon and check to make sure u have no double gasket
Old Aug 1, 2003 | 05:13 PM
uNF$@#!'s Avatar
yep.
i'm doing a valve adjustment in 4k miles. i will clean the motor and look for oil afterwards. the car has always lost oil so it's burned/leaked since purchase.</TD></TR></TABLE>
...hate to say it but the fucktard who drove your car off the ship probably beat on it bad
Old Aug 1, 2003 | 05:59 PM
GZR4DR's Avatar
Default Re: oil leak from filter mount on block? (Soup ****)
Oil filters are supposed to be hand tight only, the wrench is only supposed to be used for taking off the filter. Also no need for sealant if using say a fram or honda filter, just take a dab of oil and wet the surface all the way around, make sure block surface is clean and hand tighten it on. You can get leaks by over tightening.
As for changing cams and getting leaks, you can have oil leak from the cam seals. On these i do use either Honda Bond or Ultra Gray. Just use a thin layer and your set.
ChokolAwt
Feb 22, 2011 02:52 PM
chiaxi2002
Apr 9, 2010 08:56 PM
italstallion
Sep 5, 2007 12:08 PM
obd0crxMT
Mar 23, 2007 10:09 PM
NINJA
Aug 2, 2003 11:56 AM
