b20 with 12.5 Compression...sleeve?
Old May 11, 2003 | 08:46 AM
civicsittingon17's Avatar
Default b20 with 12.5 Compression...sleeve?
I was wondering if everyone is sleeving there b20 running a high compression. Or if anyone has had experience with "poleing" or "pinning" a block where studs are used through the water jacket and into the cylinder walls. This method seems better allowing more coolent to flow. I am just looking for someones input. I am getting to the point in my motor build where i need to make this decision.
any info on what sleeves are the best. Darton vs. Golden eagle?
Any input from someone that has built this motor would be greatly appriciated.
Old May 11, 2003 | 01:31 PM
Default Re: b20 with 12.5 Compression...sleeve? (civicsittingon17)
ttt
Old May 11, 2003 | 02:23 PM
teg92's Avatar
I would suggest pinning it by somebody who *really* knows what they are doing.
Old May 21, 2003 | 03:18 PM
Default Re: b20 with 12.5 Compression...sleeve? (teg92)
ttt
Old May 21, 2003 | 04:47 PM
Blaze45's Avatar
Brrraaaap!
With a properly installed GE blockguard you should be fine... As long as you replace the bottom end and spring/retainers you can rev up there a ways... prolly 9k..... I dunno it all depneds on tunning.. Good Luck
Blaze
Old May 21, 2003 | 07:05 PM
4DeepCivic's Avatar
Default Re: b20 with 12.5 Compression...sleeve? (Blaze45)
Is that safe? Doing 9k on a b20 resleeved... I know B20's have the siamese sleeves. Those are suppose to be weaker than individual sleeve.. Just wondering...
Old May 21, 2003 | 07:10 PM
chet's Avatar
Default Re: b20 with 12.5 Compression...sleeve? (4DeepCivic)
resleeve the block, i've seen several sleeves crack and it wasn't just because of a lack of tuning.
do things correctly the first time...
Old May 28, 2003 | 10:26 AM
X-Mazda 3 Racer's Avatar
Default Re: b20 with 12.5 Compression...sleeve? (chet)
I agree with Chet. Re-sleeve the thing and pay a little now, or alot more later!
Old May 28, 2003 | 11:00 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: b20 with 12.5 Compression...sleeve? (GoldenEagleMfg.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldenEagleMfg.com &raquo;</TD></TR><TR><TD CLASS="quote">I agree with Chet. Re-sleeve the thing and pay a little now, or alot more later!</TD></TR></TABLE>
do it right the first time or you will pay later. One way or another GE will eventually see that block
Old May 28, 2003 | 12:53 PM
Samsonite's Avatar
i ran 11.5:1(endyn pistons) on stock sleeve's and rods, with built head(crane internals, crower cams) and had no problems.
boostedb20ek
Dec 17, 2013 03:48 AM
Del Sol
Mar 3, 2013 12:39 PM
775JDMEG
11
Oct 19, 2010 08:59 AM
blackeg
Aug 9, 2008 03:06 PM
jdmEF8racer
Apr 17, 2006 03:48 PM
