finished h22 car swap but?
Old May 11, 2003 | 01:23 AM
preluder's Avatar
Default finished h22 car swap but?
I have many problems with my car. It stutters alot when i first start it like it wants to conk out then it revs up again. 2) when i leave off after puting the car in gear without using the throttle to move it it shakes hard . 3) most of the time it vibrates when i shift the car going into any gear around 2000 rpm to 3000 rpm and it hesitates in between. 4) the car when im driving smells like rich gas exhaust feels like it wants to burn my eyes out honda motors shipped me a oxygen sensor that was cut. Can you use one from off a f22a? A new relase bearing was installed but still makes a tiny squeeking noise what did the installer do wrong? also when i run the car hard due to idling problems it makes a dunk noise and I dont even powershift. OH and by the way booga,shorty whatever his name is did this swap so all of you guys that wanna go to his shop beware he and his whole ****** crew is inexperienced,also they are a bunch of con artists how are they gonna charge me extra for a misinstallation that they screwed up on.. so they all get
Modified by preluder at 2:34 AM 5/11/2003
Old May 12, 2003 | 03:38 PM
preluder's Avatar
Default Re: finished h22 car swap but? (preluder)
can i actually take these guys to court and make them pay for their negligence?
Old May 12, 2003 | 06:23 PM
sloaccord's Avatar
New User
first of all, get the car tuned. go somewhere with a dyno. it's well worth it.
check all your vacuum lines; find either a prelude or a swapped accord and compare how his are run to how yours are run. make sure none of them are worn and have holes.
try a different ecu.
yes, you can re-use the o2 sensor. i did.
did you get an act clutch? their release bearing always squeak at first; mine did; it goes away, eventually. mine took a month to go away. the installer didnt do anything wrong.
you 'leave off'without using the throttle? that's great for you clutch. dont do that. if it vibrates, check all your engine mounts. they're probably worn or busted.
if the car isnt idling correctly, makes dunk noises and vibrates, DONT DRIVE IT HARD.
the guys that put it in aren't con artists; this is all stuff i dealt with on my install. by doing something like this you have to expect that it's not all going to work perfectly right at once.
Old May 13, 2003 | 02:42 PM
preluder's Avatar
Default Re: finished h22 car swap but? (sloaccord)
i feel you bro but the guys are still ******** at that. thatnks for the advice though im sure to get it fixed tommorrow.
Old May 13, 2003 | 03:52 PM
Nick M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preluder &raquo;</TD></TR><TR><TD CLASS="quote">i feel you bro but the guys are still ******** at that. thatnks for the advice though im sure to get it fixed tommorrow.</TD></TR></TABLE>
you're in queens, go to DRT man, where the hell did you have that hack job done?
Old May 15, 2003 | 03:00 PM
preluder's Avatar
Default Re: finished h22 car swap but? (Nick M)
boogas shop
Old May 19, 2003 | 11:01 PM
COMplex.'s Avatar
DRT #1
in NY choose no other
Old May 20, 2003 | 06:50 AM
Nick M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preluder &raquo;</TD></TR><TR><TD CLASS="quote">boogas shop</TD></TR></TABLE>
the name alone i wouldnt go there lol
go to DRT, they know what they are doing
Old May 20, 2003 | 07:40 AM
92hybridAccord's Avatar
From: In the heart of the ghetto of the, Suburbs NYC
where is this "boogas shop" located...so the rest of us can beware...but DRT is legit
Old May 20, 2003 | 10:20 AM
twkdCD595's Avatar
Default Re: (92hybridAccord)
bogus shop... they need a name change.
Old May 20, 2003 | 03:35 PM
preluder's Avatar
Default Re: (twkdCD595)
his shop is in long island is you see a shop with no name dont go
daught
Honda Civic (2001 - 2005)
11
May 13, 2013 03:57 PM
jpeacock86
May 25, 2011 04:16 PM
bmrgold
Apr 17, 2004 03:21 AM
