several problems after swap
Old May 10, 2003 | 06:02 PM
Foozball26's Avatar
Default several problems after swap
Hey guys I have a 98 Civic EX and swapped in a 95 B18B using the OBD-2 Civic Harness with the AEM EMS
Ever since I swapped the motor in my A/C, Horn, and cruise control doesn’t work. Also the SRS light is always on.
I checked the fuses and everything is ok, the horn works if I jump power to it so it must be electrical, The A/C works if I jump straight power to the compressor, and I don't care about cruise control.
I do however need to find out about the SRS light so god forbid I am in an accident it will deploy, I have tried resetting it using the papr clip method but it pops back on after a few seconds of going off.
I know this is a lot to ask, but I am at my wits end trying to figure all this out
Thanks
Old May 10, 2003 | 08:33 PM
Blaze45's Avatar
Brrraaaap!
Default Re: several problems after swap (foozball-26)
Is your ECU throwing any codes? bump for someone who needs help...
Blaze
Old May 10, 2003 | 11:20 PM
MikeMAN's Avatar
jump ur ECU to see what codes u may be throwing
mike
Old May 11, 2003 | 02:20 PM
Foozball26's Avatar
Default Re: several problems after swap (MikeMAN)
no codes the check engine light is off.
Old May 11, 2003 | 02:28 PM
K20  EG's Avatar
if the ems is in there ..it wont throw a light
if you have a stock ecu ..use that to grab the codes
Old May 11, 2003 | 05:53 PM
Foozball26's Avatar
Default Re: several problems after swap (B20---Vtec)
ok ill try my stock ecu to see.
Old May 11, 2003 | 09:23 PM
wm5holla's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">jump ur ECU to see what codes u may be throwing
mike</TD></TR></TABLE> WTF are codes?
Mesm23
Jun 13, 2017 09:11 AM
cuseikan
Aug 18, 2008 01:26 PM
Cameron60
Jan 16, 2007 08:03 PM
Foozball26
May 10, 2003 08:04 PM
Foozball26
May 10, 2003 06:52 PM
