VAFC HACK, on all motor . took my turbo off
I just swaped out my d15 for a b20. i wanted to know .. how will it run with the 450 dsm injectors and the vafc hack. OR what do i need to do to the vafc to get it to run great with the 450's and ALL motor....
can someone that has done this give up there setting or maybe point me the right way.. .... BTW.. Car is running great with the 450's right now... just i need to get a smog .. ? HELP
Your going to have to crank it down to about -42 across. It might even run a little rich that way. Depends on your elavation also. A little richer if you are in the highlands.
Your running it at -42 with boost? How much boost are you running? Under 4 or what? I have mine set at about -34 at full throttle across. Maybe your elavation is a bit higher than mine?
I HAD>>> i d15b2 with SI FI, and homemade turbo running 9 psi, running custom turbo ecu chip, and 450 dsm and inline pump with base fuel pressure at 38, and it was -40 to -38-9k ran sweet..
What should i run the vafc at for all motor b20b ..... with the 450 dsm's and inline and base fuel at 38. Also im running it at -40 across narr and wide right now and running fine.. just get a lobe like idle ..and vac gauge is going 18-21 with the lobe idle...? should do this.. with stock cams ..right ?
Try -42 all the way across. Subtract more if you're bogging or puffing black smoke out.
If you still have probs, I'd swap that inline with an intank. HTH
just wanted to know.. if anyone had tried this... and if someone out there has some setting i could try to get a lilte more power... The b20 runs so good.. just i get a lobe like idle... and well just wanted to know if i could get more out of it
If it helps, I run a d16a6 with the filetofit circuit (much like the VAFC) and run 450cc injectors N/A. I initially got the lumpy idle due to running lean at idle, turned up the fuel with the controller to make it to the stioch area on my a/f guage and I could actually feel the idle getting better when adjusting with the a/f guage read out.
My car runs better with these injectors compaired to stock and idles stock also. Took about 15 minutes of tuning to get the car running perfect from when I installed it.
Not a VAFC, but all you really need to do is tune it in yourself and it wouldn't hurt to have an A/F gauge to tune by. By the way, I left my fuel pressure stock and it works out fine. I don't run any richer than I did with the stock injectors.
got a question on the 450cc dsm injectors...
i got a set of 2nd gen 450cc dsm injectors and wanted to know if when i use the vafc can i use these injectors in my 2.3vtec prelude, without turbo?
at the time i couldnt find anyone that had any. i did a head swap.. so now its a 2.3 vtec.. (2.3block with the 2.2vtec head) and just wanted to see if the dsm with the vafc hack would work.. i got the 99 gsx injectors (450cc black tops) and with the vafc could lower the fuel rate (im guessing )
my response was actually directed at the orig post, not yours. sorry
stock injectors really aren't hard to find, and can be had pretty cheap. ****, some people would probably trade you for the DSM's if you could afford the down time for shipping....
oh i dont have them in .. i just got them off an auction.. right now im running with the prelude si injectors..(i dont know the cc rate on them) i got a set of GSR injectors but wanted to beef it up sum and been reading about this Vafc hack.. so i was curious if it would work since i got them, i got a set of 2000 prelude injectors but i need peak and hold and havnt looked much into swaping them.. i just found this site like a day ago
Car runs fine with the dsm 450's.... I'm looking for power setting.. something better maybe then just -40 across.....just wanted to know if anyone did this mod.. I was turbo .. and I am going turbo.. that is why im not running stock injectors , turbo should only be about another week or 2
b16booster
Sep 19, 2003 10:45 AM
