help changing water pump
Old May 10, 2003 | 09:56 AM
1bad_crx's Avatar
Default help changing water pump
Well it happened, i bought a salvage motor and didnt replace the water pump. And guess what needs to be changed now. yep and i have never changed a water pump that is ran with the timing belt like this one.so does any body know how do it step buy step. thanks in advance.
Old May 10, 2003 | 10:11 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: help changing water pump (1bad_crx)
Yes, there are these things, ussually 8 1/2 by 11 wrapped in clear plastic.
you get them at auto parts stores, I think they are called books.
You need a service book for your car, helms, whatever.
it is a lenghty process, not difficult, but lenghty.
You need pictures that explain the process as well as text.
I doubt someone here is going to sit down, post pictures and write a complete write up for you.
If you like to work on your car you MUST have a service book.
Old May 10, 2003 | 10:33 AM
1bad_crx's Avatar
Default Re: help changing water pump (Spaceballs the lunch box)
auhhhhh....duh. but i was just looking for some steps in the procedure not a detailed freging diagram. although it would be appreciated. see some people on this board are cool fellow tuners who dont mind helping a fellow gear head. but thanks for the input (insert smart remark here)[ ]
Old May 10, 2003 | 12:38 PM
blah13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bad_crx &raquo;</TD></TR><TR><TD CLASS="quote">auhhhhh....duh. but i was just looking for some steps in the procedure not a detailed freging diagram. </TD></TR></TABLE>
You need a "detailed freging diagram." Unless you want to replace it again after you half-*** it.
Old May 10, 2003 | 01:04 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
try this: http://www.crxsi.com/resources...belt/
dertymatt
Mar 2, 2009 08:38 AM
jacob3
Nov 20, 2006 12:36 PM
turq93t
10
May 16, 2005 06:00 PM
pnthr30
Oct 28, 2003 08:38 AM
typeeg
Aug 2, 2003 10:22 AM
