My SRS system is fuk up. help.
Old May 10, 2003 | 04:49 AM
GSblueRacing's Avatar
Default My SRS system is *** up. help.
This is how it all began. Few days ago My dash was worked on by friends/the shop. Steering wheel was taken out. After Dash done, Steering wheel was put back. While driving home, I found out that the steering wheel (center "A") had to be pointed at 11 o'clock for the car to drive straight. If let go, the wheel would stay at 11 o'clock and car would go straight(so I know it's not alignment or tires). When I turned my steering wheel ALL the way to the LEFT or RIGHT, the center("A") would point at 5 O'clock either way. which is not normal because it should be 7'ocl and 5'ocl respectively.
Took it back, Recenter the steering wheel. Wheel was straight that day/night. BUT the center ("A") now points at 6 O'clock when I turned the wheel all the way LEFT or RIGHT. Next day when I tried to drive car, SRS light came on and off(with a beep first) WHENEVER I tried to move the steering wheel right or left, ESPECIALLY to the right. Even when idling.
Took it back once again. Removed steering wheel, Reinstalled, this time the SRS lights just stayed ON. ALWAYS on now.
What could be the problem? sensors? the connectors? airbags? toes?
the shop told me the problem is #4(in the pic),Reel assay damaged?
Old May 10, 2003 | 08:57 AM
IntEGNYC's Avatar
Default Re: My SRS system is *** up. help. (GSblueRacing)
what kind of work did you do that required removing the steeringwheel to get to the dash?
Old May 10, 2003 | 10:22 AM
Default Re: My SRS system is *** up. help. (SonicGSR)
we were swapping an old dash out. how do you reset ecu?
Old May 10, 2003 | 01:03 PM
Eziekel's Avatar
unplug your battery and unplug your ecu for awhile. and then plug it back in. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSblueRacing &raquo;</TD></TR><TR><TD CLASS="quote">we were swapping an old dash out. how do you reset ecu? </TD></TR></TABLE>
Old May 10, 2003 | 05:30 PM
integrasi's Avatar
Default Re: My SRS system is *** up. help. (Kunfusion209)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kunfusion209 &raquo;</TD></TR><TR><TD CLASS="quote">unplug your battery and unplug your ecu for awhile. and then plug it back in. </TD></TR></TABLE>
yup, that should fix the problem. just take the battery out for couple of min. & install back in.
Old May 10, 2003 | 10:48 PM
743power's Avatar
Default Re: My SRS system is *** up. help. (integrasi)
Unfortunately, resetting the ecu has nothing to do with the SRS computer. You'll have to reset the SRS. You can take it to the dealer, which is like $60 to do. You can do it yourself or tell your friends shop to do it. Check the H-T archives. . .
Old Oct 9, 2003 | 08:24 PM
Reza.dc's Avatar
Default Re: My SRS system is *** up. help. (743)
can someone tell me what part number 4 is called.
Its the unit that goes on before the wheel. If that component comes apart and the reel like ribbon is exposed, is that module still good? Thanks
Old Oct 9, 2003 | 08:49 PM
BolivianDc2's Avatar
Default Re: My SRS system is *** up. help. (reza)
Just out of curiousity, does anybody know how much the SRS brain (part #20 wieghs?
Old Oct 9, 2003 | 10:20 PM
b19coupe's Avatar
If part #4 (the cable reel) was not installed correctly, and it sounds like it was not, it becomes damaged. An open circuit is created between the SRS ECU and the driver's airbag, hence the SRS light. Resetting the ECU will not cure the problem. A new cable reel, installed correctly, and then reset the SRS light. They are not cheap, BTW.
Old Oct 9, 2003 | 10:38 PM
Calavera's Avatar
Default Re: My SRS system is *** up. help. (b19coupe)
right now my SRS light stays on because the steering wheel I bought has SRS plugs that do not match my 95 GSR ones. So they're not connected. Does this mean I could have damaged #4 as well?
Old Oct 10, 2003 | 01:12 AM
Reza.dc's Avatar
Default Re: My SRS system is *** up. help. (Calavera)
is my #4 has been split open by the force of removing it, so the reel unraveled.
Is it damaged or can i reel it back up ? Thanks
Old Oct 10, 2003 | 05:28 AM
b19coupe's Avatar
It's possible to put the cable reel back together, I had to do it once. Just depends on how badly it came apart. If it was installed out of synch and damaged, it will need to be replaced.
Danielsb20crx
39
Jan 6, 2013 01:02 PM
vti444
Jun 16, 2007 02:36 PM
GSblueRacing
May 10, 2003 05:59 PM
