whats best piston 4 b16a2?(upgrade)
Old May 9, 2003 | 10:06 PM
[DIGGA]'s Avatar
Default whats best piston 4 b16a2?(upgrade)
just wandering what is d best piston 2 get 4 my b16a2 coz i want higher comp ratio but still can b daily driven and wont ping d engine?
Old May 9, 2003 | 11:12 PM
ExospeedAMcrx's Avatar
Default Re: whats best piston 4 b16a2?(upgrade) (NUR-21U)
the b16a2 already has a pretty good compression... but if you want a mild upgrade.. a CTR piston is good enough. jus a bit ofa bump on the compression ratio. but if you want more compression, you can go with an ARIAS or JE piston set. but once you go higher than the CTR piston, the more chances of detonation. it can be aily driven, but have to be tuned well and use highest octane possible to prevent detonation
vinuneuro
Jul 30, 2005 10:51 PM
Seraph0
Jan 10, 2004 05:40 PM
juicedricer
Jul 16, 2003 02:10 PM
*Boostwerks*
Oct 10, 2002 04:43 AM
