Converting mm to degrees
Old May 9, 2003 | 05:42 PM
ryanstev's Avatar
Default Converting mm to degrees
I took some measurements of my rear toe the other day, left: 4 minutes, right 5 minutes.
The specs say they should be 2mm ± 2mm.
I've forgotten how to convert angles into distance, or even if you can, does anybody know?
Old May 10, 2003 | 03:45 PM
ryanstev's Avatar
Default Re: Converting mm to degrees (ryanstev)
Any ideas?
Old May 12, 2003 | 08:50 AM
JimBlake's Avatar
first, 60min = 1 degree.
Convert angle into distance you need the diameter over which you want the measurement. I'm guessing the bead diameter of your wheel, like about 15"...
toe = diameter * sin(angle)
or...
toe = 15" * sin(4/60)
= 0.017" = 0.44mm
Old May 16, 2003 | 08:29 PM
ryanstev's Avatar
Default Re: Converting mm to degrees (JimBlake)
Thanks so much for the reply.
Old May 16, 2003 | 08:53 PM
9200RPM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">first, 60min = 1 degree.
or...
= 0.017" = 0.44mm
holy crap!!!
hgem1si
Sep 30, 2008 09:25 PM
Import Prelude
May 13, 2007 04:28 PM
Autoworks
Aug 10, 2005 03:32 AM
DonKey or Horse
Aug 10, 2004 10:38 AM
ebp 99 si
13
Aug 2, 2004 06:21 PM
