This ever happen to any of you? Hawk HPS backing plate...
Old May 9, 2003 | 05:39 PM
yellow blur's Avatar
Default This ever happen to any of you? Hawk HPS backing plate...
Rear brakes, stock ITR rotors at ~35k. I'll let the pictures speak for themselves.
Comments anyone?
Ed
Old May 9, 2003 | 06:03 PM
SpiceyRice's Avatar
Default Re: This ever happen to any of you? Hawk HPS backing plate... (yellow blur)
So the back plate came loose and scored your rotor? Big deal. The groove won't have any affect on your rotors.
Your rotors and pads look like they're about done anyway. I just ordered some Cobalt Frictions and the build quality looks top notch and I'm testing them out next weekend, I'll see how they do.
Old May 9, 2003 | 06:30 PM
uNF$@#!'s Avatar
Default Re: This ever happen to any of you? Hawk HPS backing plate... (SpiceyRice)
think of it as unsprung weight reduction
Old May 9, 2003 | 06:34 PM
Asahi's Avatar
Default Re: This ever happen to any of you? Hawk HPS backing plate... (Soup ****)
happens all the time. Not a big deal. No ill effects to removing them. Happens on HPS and HP+. THey are the ones to come with plates to reduce squeal.
pull them off and don't sweat it.
Old May 9, 2003 | 06:37 PM
aaj23's Avatar
Yeah, it happened on a front set that I had on my car...glad to hear I'm not the only one...
Later,
Aj
Old May 9, 2003 | 06:38 PM
typer100's Avatar
Seen that before... I had Hawk HP+ front pads. It made a nice little tread on my front left rotor. Exactly like yours did. Not much harm done. The right one never had the chance do the same I just took the little plate out before.
I should have complain to Hawk... Maybe they would have send a new set of pads for free!
Old May 9, 2003 | 06:40 PM
IN VTEC's Avatar
Happened to mine. I make it a point to remove them the first time so I or the person I install them for doesn't have to deal with it later on.
Old May 9, 2003 | 06:59 PM
onyx00's Avatar
Default Re: This ever happen to any of you? Hawk HPS backing plate... (IN VTEC)
Happened to me; ******* Hawk pads suck. Call them; you can get a free pair of them.
You don't need the shims; just take them off; did that on mine and they worked fine. Well until I glazed the rotors at least...
Old May 9, 2003 | 07:00 PM
N1-R's Avatar
New User
i'm also a victim of Hawk pads and their gayass backing plates coming off.....happened to my front rotor, made a niceeeeeee deeeeeep groove on the rotor hat.
Old May 9, 2003 | 08:30 PM
nighttime's Avatar
New User
You have two options. The first option is to take the shim out and leave it out. The second option is to put liquid anti squeal compound on both sides of the shim (clean it first if the shim was glued to the pad), put the shim and the pad back in the caliper, then drive the car around and do a few stops to heat up the brakes. What will happen is the anti squeal compound will bond the shim to the pad and the caliper, and it wont slide anymore. The same thing happened to my Carbotech Super Street F pads, and thats what I did to fix it.
Old May 9, 2003 | 08:33 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
That happened to one of the front pads on my car, just put more anti-squeal on there and reinstalled. **** happens.
Old May 9, 2003 | 09:40 PM
Warren's Avatar
Wrong-Way Wang
Default Re: This ever happen to any of you? Hawk HPS backing plate... (N1-R)
Before your gayass says something, how about you know what you're talking about? It's not a backing plate. If the backing plate fell off, you'd know... It's a shim, and it's just for noise. Take it out.
Groove on the rotor hat? Great. Less unsprung weight.
Warren
Old May 9, 2003 | 10:51 PM
Default Re: This ever happen to any of you? Hawk HPS backing plate... (Warren)
Thanks for the comments guys. I know that it's not detrimental to the preformance, just wondering if it happened to you guys before. Hawk is teh SUCK! Hehe, anyways thanks again.
Pads are relatively new, but rotors going soon.
Ed
Modified by yellow blur at 1:40 AM 5/10/2003
Old May 10, 2003 | 06:51 AM
SpiceyRice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Warren &raquo;</TD></TR><TR><TD CLASS="quote">Before your gayass says something, how about you know what you're talking about? It's not a backing plate. If the backing plate fell off, you'd know... It's a shim, and it's just for noise. Take it out.</TD></TR></TABLE>
Hawks are generally good pads, the shim coming loose doesn't indicate low quality workmanship, prolly just a bad install.
Referring to my post Chuckles? I think we all know it's not the "backing plate", if we had, we all would have all said chuck the pads.
I wasn't sure if it was the shim or the "back plate" of the pad. I've never dealt wiith Hawk blacks, just blues and they either don't come with shims, or I throw them away immediately and never had to deal with them.
attitude
Old May 10, 2003 | 08:52 AM
machgo5go's Avatar
Spray some anti squeak blue glue on the plate before u install so it will stick onto the caliper inorder to prevent this.
Old May 10, 2003 | 09:36 AM
uncleben's Avatar
Default Re: This ever happen to any of you? Hawk HPS backing plate... (machgo5go)
I'm going to have to agree with Warren here. And have any of you "Hawk pads suck" raced on Hawk pads? Just take the stupid things out...
Old May 10, 2003 | 11:14 AM
Chris's Avatar
Warren</TD></TR></TABLE>
Well said. I second this post.
NuRon
Mar 10, 2008 05:51 PM
MDM
21
Aug 20, 2007 09:54 PM
civic_saints1
Jun 22, 2007 03:25 AM
R81_DC2
Mar 30, 2007 10:23 AM
FORTIS
Oct 2, 2002 04:47 PM
