car hesitating and bogging
Old May 9, 2003 | 02:51 PM
ravi's Avatar
Default car hesitating and bogging
sup guys
i have a problem with my car....today when i started her up in the morning and drove off i noticed my car was hesitating to go and bogging..when i was accelerating all of a sudden it bogged for 1-2secs and then pressed the gas a lil more and it was normal again....this kept happening, especially when i took off from first gear....what could be the problem?
i washed the engine a few days ago...and was sure i covered the distrubtor
Thanks
Old May 9, 2003 | 03:02 PM
deebee-II's Avatar
I have this problem too. i don't think it would of been due to washing of my engine. But at 1st and 2nd gear, at around 2-3000rpm my car hesitates like it's choking for a bit then stops doing that after 3K I'm not flooring the gas and i'm just accelerating normally.
Some say it might be my O2 sensors, or maybe i'm running too rich due to my FPR set at 41psi instead of the stock 38psi. I have cai, dc headers and cat back...that's it. I don't know why the previous owner of my car set it at 41 psi and i've benn too lazy to turn it back down to stock. So yeah, what do you guys think is our problem? Oh and this doens't happen all the time...only sometimes...
Old May 9, 2003 | 04:39 PM
arsenaldragster's Avatar
Default Re: (deebee-II)
check (replace) your 02... i had the SAME exact problem.. eventually your check engine light will come on.. then i can say "i told you so" hope this helps! Let us know
Old May 11, 2003 | 08:41 AM
deebee-II's Avatar
Default Re: (arsenaldragster)
i'll try that.......there's only one O2 sensor near the cat rite?
cuz sometimes i scrape when i hit the long speedbumps, maybe that messed it up
Old May 11, 2003 | 10:25 AM
bikeboy80's Avatar
its either that or could be the tps sensor
Old May 11, 2003 | 10:56 AM
NeoGSR's Avatar
Default Re: (bikeboy80)
dirty fuel filter?
Old May 11, 2003 | 11:46 AM
ravi's Avatar
Default Re: (NeoGSR)
solved my problem...i had water in the spark plug holes....dried it out and now its fine....must have gotten in there when i was washing the engine..hehe
Old May 11, 2003 | 02:32 PM
Eziekel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arsenaldragster &raquo;</TD></TR><TR><TD CLASS="quote">check (replace) your 02... i had the SAME exact problem.. eventually your check engine light will come on.. then i can say "i told you so" hope this helps! Let us know</TD></TR></TABLE>hey wassup im from stockton and im running OBD2 and im having the same problem my car is bogging as well and my check engine light keeps coming on. you think its the O2 sensor? i use the obd2 machine to find out what was it and it said code 21 and thats the "vtec switch" but i was thinking maybe my o2 sensor is messed up as well..
Old May 11, 2003 | 09:35 PM
Danger's Avatar
Default Re: (Kunfusion209)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kunfusion209 &raquo;</TD></TR><TR><TD CLASS="quote">hey wassup im from stockton and im running OBD2 and im having the same problem my car is bogging as well and my check engine light keeps coming on. you think its the O2 sensor? i use the obd2 machine to find out what was it and it said code 21 and thats the "vtec switch" but i was thinking maybe my o2 sensor is messed up as well..</TD></TR></TABLE>
Ez , when did u get an integra ?
Old May 12, 2003 | 04:02 PM
Default Re: (JonnyDanger)
Ill give you $15 for that intercooler btw.. do you know where i can find a interfooler?? j/k
Old May 12, 2003 | 04:03 PM
check the o2.. it just might be it! what car you drive?? we should do a local meet to find out whos who.
Old May 12, 2003 | 04:16 PM
Danger's Avatar
check the o2.. it just might be it! what car you drive?? we should do a local meet to find out whos who.</TD></TR></TABLE>
i already know who your are jk
*Ez , take ur **** to CBi .
Old May 12, 2003 | 09:37 PM
DeSolMan007's Avatar
Default Re: car hesitating and bogging (ravi)
here is a quick way to tell if it is your TPS. Unplug it and drive it for a while. Drive it gently. It will throw a check engine light right away but you will be fine. I have had a problem with my car and everyone said it could not be the TPS because of this and that. Unpluged it two days ago and it is running fine. Plug it back in the car stumbles within the first 20 feet.
Good luck
Old May 13, 2003 | 06:32 AM
n0 iNTegRiTY's Avatar
with hesitation, I'd say the most common problem is either dirty and clogged injectors, or need to replace spark plugs and/or spark plug wires....or in your case, water in the port.
schpiel
107
Aug 17, 2008 04:21 AM
dinko
Sep 13, 2006 10:46 PM
psilo
Sep 29, 2004 12:20 PM
