Questions Regarding Hitting the REV Limiter.
Old Jul 6, 2001 | 08:39 PM
AdamITR's Avatar
Default Questions Regarding Hitting the REV Limiter.
Yes ... I've done a search.
I was wondering if someone could explain what is occuring when you "Hit the Rev Limiter?" Is the fuel cut-off, causing a lean condtion with possible detonation? Or do the injectors stop providing fuel, causing no combustion? I'm asking because I hit the rev limiter twice today ... once in second and third. I know that it's not a good idea, but should I be worried? Also, what are the possible ramifications of hitting the rev limit? Bent valves? What would be the indication of engine damage? Thanks
Old Jul 6, 2001 | 09:13 PM
Type Goch's Avatar
New User
Default Re: Questions Regarding Hitting the REV Limiter. (AdamITR)
dont worry about hitting the rev-limiter. Worry about valve-float, (when you take your revs way past redline during a downshift).
Old Jul 6, 2001 | 09:42 PM
travis's Avatar
Default Re: Questions Regarding Hitting the REV Limiter. (Type Goch)
Smoke, fire, new noises, or the CEL are the usual indications that you have screwed something up. Without those (and assuming that everything feels fine) you're in good shape.
The limiter is there to prevent you from doing damage, not to cause damage. I hit it roughly 10x/week at each race when there's not enough benefit (ie, space) to shift. I suspect that if you sat in your car in neutral and just let it bounce off the limiter you could float a valve, but you could overheat just as fast. Being on the limiter means more frequent valve adjustments, oil changes, and well-baby checks, but not certain doom.
Old Jul 7, 2001 | 06:35 AM
AdamITR's Avatar
Default Re: Questions Regarding Hitting the REV Limiter. (ITR#231)
Thanks ... I was a bit worried for awhile.
JDM00SI
Sep 17, 2004 01:14 PM
Sam1am26
Apr 20, 2004 08:29 AM
DeDonDeRosa
Sep 11, 2002 10:18 PM
htludernewbie
Aug 25, 2002 03:06 AM
4wsB21a
Feb 4, 2002 12:44 PM
