H22 Shifter & Shift Cables... will these fit?
Old May 9, 2003 | 02:22 PM
COMplex.'s Avatar
Default H22 Shifter & Shift Cables... will these fit?
ok, i used one of those junkyard search things and someone has a set. my question is, will these fit?
this is the email i recieved:
"THE SHIFTER ASSEMBLY THAT WE HAVE IS ONLY FOR A
REGULAR 2.2 MT. PRELUDE NOT A VTECH MOTOR"
now does that mean its not for h22? will it fit?
i thought one model used only one cable instead of two. is this true?
help! thanks
Old May 9, 2003 | 02:36 PM
2trix's Avatar
Default Re: H22 Shifter & Shift Cables... will these fit? (j.fuggi)
if its 92 and up lude then youll be fine! also 90 and up accord will work...im not aware of a one cable shift tranny!? maybe an auto....but if its manny youll fine!
Old May 9, 2003 | 02:49 PM
COMplex.'s Avatar
Default Re: H22 Shifter & Shift Cables... will these fit? (2trix)
are you 100% sure?
Old May 9, 2003 | 03:16 PM
2trix's Avatar
yes on a manual transmission prelude from the year of 1992 upto their demise the cables will work for civic/h22 swap! 100% sure! im sure they just looked up in inventory for vtec and then whatever parts they have...other than that you could always email or call em just to make sure?
Old May 9, 2003 | 03:24 PM
COMplex.'s Avatar
ok just making sure. i really need the part and i really want to get this swap done. $75 isn't bad at all
Old May 9, 2003 | 06:31 PM
sappsycho's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">"THE SHIFTER ASSEMBLY THAT WE HAVE IS ONLY FOR A
REGULAR 2.2 MT. PRELUDE NOT A VTECH MOTOR"</TD></TR></TABLE>
Just remember, this assembly will not work with your cordless phone!
huge230
Aug 3, 2005 08:26 PM
BIGBLOCKEK
Jul 21, 2004 01:26 PM
btlfed1
Jun 16, 2003 01:15 PM
iwhichisme
Mar 24, 2003 08:13 AM
