JDM H22A Gas requirements?
Old May 9, 2003 | 12:32 PM
deevergote's Avatar
Default JDM H22A Gas requirements?
I searched, and I'm pretty sure I know the answer to this already... However, I figured I would ask anyway, just to be sure. I'm getting a JDM H22A next week. I currently use 87 octane in my 92 Accord.
I'm guessing I should use premium (93) when the H22 is in? Someone told me today that a JDM engine needs higher octane gas than we have available at most pumps (like 106), is this true?
What would the effect would using low octane gas have on the engine? In other words, if I stick to 87, will I blow it up?
Old May 9, 2003 | 12:39 PM
93acclude's Avatar
Default Re: JDM H22A Gas requirements? (deevergote)
The USDM h22 needs premium gas. I assume the JDM version is the same. I would use at least 91 octane.
Old May 9, 2003 | 01:26 PM
CD8's Avatar
CD8
Default Re: JDM H22A Gas requirements? (93acclude)
91... if you can 93
Old May 9, 2003 | 03:41 PM
deevergote's Avatar
Default Re: JDM H22A Gas requirements? (exaccord)
Yeah, in my part of Jersey we have 87, 89, and 93. At least the prices aren't bad... they're bad for here, but they're nowhere near the rest of the country! $1.49 for 93
I'll miss getting over a half tank of 87 for $10, but hey... I'm sure the H22 will be worth it!
Thanks!
Old May 9, 2003 | 05:22 PM
PHATh22aWAGON's Avatar
sup i have a jdm h22 in my accord wagon i use low octane gas sometimes nothin ever happens to mine if you start shootin nos or wanna go turbo then start using higher octane but for a stock motor you can use what ever unleaded gas in the gasstation
Old May 9, 2003 | 05:24 PM
deevergote's Avatar
Default Re: JDM H22A Gas requirements? (PHATh22aWAGON)
Sweet! Thanks! That's good to know.
Since you're in NJ, do you pass emissions at the inspection station, or do you pay to have it pushed through a private place? I've been told lots of stories about emissions and stuff, but nothing based on experience.
Old May 9, 2003 | 05:48 PM
well for one my car is dropped i would fail inspection right there.....i go to a private place for 90 dollars the guy gives me a scrapper and the sticke and tells me to put the sticker on myself by the way make sure you have all the right parts to do the swap iran through so many problems it aint even funny holla back at m for any other questions
Old May 9, 2003 | 09:32 PM
Nick M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHATh22aWAGON &raquo;</TD></TR><TR><TD CLASS="quote">sup i have a jdm h22 in my accord wagon i use low octane gas sometimes nothin ever happens to mine if you start shootin nos or wanna go turbo then start using higher octane but for a stock motor you can use what ever unleaded gas in the gasstation </TD></TR></TABLE>
you need to stop spreading misinformation
you need to use premium (91+) octane with an h22a1 h22a4 or a jdm h22a, your ignition timing WILL adjust for crappy fuel and kill some power
Old May 10, 2003 | 04:32 PM
Razor's Avatar
Default Re: JDM H22A Gas requirements? (Nick M)
use atleast 91. but since money isn't a problem for me, i used 94 octane from sunoco for both of my DOHC VTEC beasts...it burns cleaner and more efficiently.
Old May 11, 2003 | 01:03 PM
sauceman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick M &raquo;</TD></TR><TR><TD CLASS="quote">
you need to use premium (91+) octane with an h22a1 h22a4 or a jdm h22a, your ignition timing WILL adjust for crappy fuel and kill some power</TD></TR></TABLE>
Right. What I thought. I guess this goes for any high compression engine with OBD2 management, right?
Would you happen to know, if I chose to use premium in summer, but 87 in winter, the ECU would adjust, but then would it re-adjust to premium again next spring??
Old May 11, 2003 | 02:15 PM
SearchBeforeUPost!'s Avatar
Default Re: JDM H22A Gas requirements? (sauceman)
alot of jdm h22s are obd1, like mine. Since the swap i have used 93 octane and not looked back. I just found out there is a station in town that sells 110 octane at the pump. I am eager to try it.
Old May 11, 2003 | 04:36 PM
Nick M's Avatar
Default Re: JDM H22A Gas requirements? (Bda91acc)
i accidentally put in 87 octane in my jdm h22a once, a full tank, and ill never do it again for the next week or so I own my car, it ran like crap
you dont use anything less than premium fuel with this motor unless its an emergency
Old May 12, 2003 | 04:15 AM
KGAccord's Avatar
when you out 87 **** water in the H22, the knock sensor will pick up pre-ignition and will retard timing. this means a slow *** car. it has nothing to do with the OBDI or II ECU.
i personally like good name brand gas 93 octane from Sunoco, Shell/Texaco, and Mobil. also, my friend has found that mobil 93 and sunco 94 runs the same. so i wouldn't waste money on sunoco 94, just get mobil 93. he had a chip in his camaro and it would ping unless sunoco 94 or mobil 93 was used.
Old May 12, 2003 | 06:05 AM
Jason kiDD's Avatar
We are having a h22/hybrid meet on June 1st in Jerz. All that are interested can add their name to the ongoing list..
https://honda-tech.com/zerothre...71041
racetowin
Jul 15, 2006 09:29 AM
tr0n9h
Sep 26, 2005 10:55 PM
type-t
Sep 4, 2004 12:33 PM
ramz7887
May 23, 2004 10:25 PM
B19CivicHB
Dec 26, 2001 09:02 PM
