d16z with a d18y8 head??
I have searched and didnt really find a definite answer and wanted to know if anyone can help me out...I am debating if I want to do this.
I have a d16z in my del sol i just bought and wanted to know if its worth it to swap to the y8 head? or is it possible to use just the IM, TB, and head gasket, etc from the y8 instead and keep my head? anything will help and appreciate..
thanks
Modified by TKL at 2:48 PM 5/9/2003
thanks
there was a large discussion on the difference between the z6 and the y8 head. supposedly the intake ports are different.
according to a picture that was posted the z6 is better for power with the ports being symetrical and the y8 was better for fuel efficiency (sp?) due to non-symetry (biased towards one of the intake valves)
Search some more or check out spade's post about sohc upgrades. This topic might be discussed in there. Or the post im referring to could have been linked in there.
The Y8 has a stronger tranny, better intake manifold and exhaust manifold, slightly more aggressive cam and higher compression ratio due to the smaller combusion chambers. The Z6 has a better flowing head and more tunable ecu.
Quite sure that he meant d16y8. I don't know that I would bother with swapping from a z6 to y8 head. The z6 head flows better on the high end. If anything, I would get the z6 head cleaned up and rebuilt. Just a mild port job, valvetrain and a new cam.
stealthcivic94
Dec 12, 2005 01:10 PM
scratchy
Oct 10, 2003 01:52 PM
crooked muffler
Mar 23, 2003 11:20 AM
Never heard of an d18y8.He ment d16 right?
