Cam question
I wouldnt say putting cams in increases wear on the engine - I would say the added strain you put on it by driving harder after getting the cams will be the wearing factor.
Thanks. I was just inquiring because I am buying a GSR next week sometime. Well thats the plan for now. Selling-My-95-GSR's car, I am going to look at it on sunday and I was thinking about dropping in Cam's. I am just looking at my options. I want to bring the car to the track quite a bit and build it up to where he had it before he parted with all his parts. It still has a great base to begin with though.
What cams do you suggest? I can post his setup if that would help out.
here is the setup:
95 GSR 56k on the car/motor.
1) Skunk 2 manifold
2) AEM Ported T-body
3) new short ram polished intake with weapon R filter
4) DPR stage 6 headwork with titanium retainers, stainless steel valves, ITR valvesprings, ceramic coating and stock GSR cams, and titanium vtec x-over pics
5) Brand new ITR tranny with JDM 4.785 FD, Fidanza Flywheel, and Exedy street clutch
6) B&M short shifter, RAZO RA18 shift **** and matching E-brake handle
7) Neuspeed front upper strut bar
8) front clear corner bumper lenses
9) S2000 antenna conversion
10) RAZO Pedals
11) KVR front brake pads
12) Comptech 22mm rear sway bar
13) Neuspeed Race springs and Koni double adjustable shocks
14) ES Hyperflexx bushing kit\
15)No power steering, cruise control or A/C.
Thanks H-T
1) Skunk 2 manifold
10) RAZO Pedals
Thanks H-T
I'll guess stock pistons and bottom end? If so then SK2 I or JUN II or Toda B or Crowers? I really recommend compression for the larger cams as you will get better gains from them. You can always run a bigger cam and up the compression later. JUN III, SK2 II, etc. of course going to a larger cam will mean upgrading the valve train again.
yes it does. a bigger cam lobe would actually make the valve travel more, correct? so that would in turn wear the valve guides quicker. not to mention the fact that bigger lobes compress your valve springs more, adding to valve spring wear. and lastly, if your valve springs are compressed more, then they are putting more force on the rocker arms, making the pressure between the rocker arm, and cam lobe greater than it would be on a stock setup, therefore wearing out both the rocker arm and cam faster. but thats just my .02 cents.
well yes and no... If you're looking for 100k results with out a rebuild then don't get cams or even mod your car that much. If you can say "I will replace things on my motor every season or so.." then cams are good, as is more internal mods, suspension, etc... you get the idea.
SiR-iNTEGRa
Mar 2, 2012 01:20 PM
