Colder, hotter plugs???
Old May 9, 2003 | 08:28 AM
toooslow's Avatar
Default Colder, hotter plugs???
I need more info on spark plugs. when would you use colder or hotter pluggs then stock?
Old May 9, 2003 | 09:13 AM
EE_Chris's Avatar
Default Re: Colder, hotter plugs??? (whiteinteg95)
NGK has an excellent article about just such a topic.
Old May 10, 2003 | 11:45 AM
toooslow's Avatar
thats a good site, but im still a little confused, is there only one plug of each, hot and cold or do they have lots of different ranges of cold and hot plugs. I went to pepboys and they said that there was only one of each, vtec engines run cold plugs oem and non-vtec engine plugs being hot oem.
Old May 10, 2003 | 01:14 PM
isp built's Avatar
colder plug than stock for turbo and nos
Old May 10, 2003 | 02:28 PM
sleeprhatch's Avatar
Default Re: Colder, hotter plugs??? (isp built)
thank you! ***right click***** ***add to favorites***
Old May 10, 2003 | 02:32 PM
aeolus's Avatar
Default Re: Colder, hotter plugs??? (sleeprhatch)
also colder plugs for high compression.
Old May 10, 2003 | 04:27 PM
sgT's Avatar
sgT
Default Re: Colder, hotter plugs??? (aeolus)
Generally you want to run the hottest plug that does not cause detonation.
Same thing with gasoline, lowest octane that does not cause detonation.
Old May 13, 2003 | 03:47 AM
rabbid's Avatar
Default Re: Colder, hotter plugs??? (sgT)
some thing to think about is this, the hotter it is the less oxygen there is in the air so you need a hotter plug to ignite the oxygen that is in the air. When it gets cooler go colder on the plug tempreture, because that the air is heaver and fuel as heavyer at night and need less fire to set off the combination. But also remember that when you use nitros you need to go colder because there is so much more oxygen in the cylinder. That is why you have to run more gas when you use nitros because of the extra O2 in the cylinder, plus the cylinder also cools way down.
Old May 13, 2003 | 05:45 AM
lke2drvgsr's Avatar
Default Re: Colder, hotter plugs??? (rabbid)
http://www.team-integra.net great articles in there...
Old May 13, 2003 | 05:56 AM
IN VTEC's Avatar
Incorrect logic.
Plug heat range does not affect the intensity of the spark, unless it's either melting or fouling the plug.
Old May 14, 2003 | 11:37 AM
toooslow's Avatar
do you think i will really hurt anything if i try a hotter plug from an ls or something into my near stock gsr with msd ignition?
123Four
Sep 22, 2007 03:28 PM
lacking vtec
May 20, 2007 11:37 AM
Quitripin
16
Aug 18, 2004 09:20 PM
CalvitoSol
Jun 15, 2002 11:01 AM
