Hmm...What now ?
Old May 9, 2003 | 08:08 AM
Resurgent's Avatar
Default Hmm...What now ? D16Y7 Q
Well I've concurred DOHC valve adjustments but when I took my valve cover off my D16Y7 things looked a bit tight under one cam. I have all the tools for b series adjustments, is there another tool that works around the rockers for SOHC wrench'n ?
Thanks
Modified by Resurgent at 12:58 PM 5/9/2003
Old May 9, 2003 | 08:57 AM
Resurgent's Avatar
Default Re: Hmm...What now ? D16Y7 Q (Resurgent)
dern it , wish I could change the topic viewed on the Tech folder - why would editing the topic be beneficial if you can't see it
Annnyway - bring on the D series Techs !!!
Old May 9, 2003 | 09:29 AM
turbochic's Avatar
when i did a valve adj. on my d16y8, i just used the normal feeler gauge, a flathead screwdriver and (if i remember correctly) a 12mm wrench. its not hard at all. since you did one on your other car you already know the basics of how to do it.
Old May 9, 2003 | 11:24 AM
Resurgent's Avatar
Default Re: Hmm...What now ? D16Y7 Q (fmaxturbochic)
Well I guess its possible, I really couldn't get the feeler gauges in between the rockers, and I do have the 10mm lock-nut wrench from snap-on - maybe I need to take another look. I took pics w/o the VC on but have no host .
Any other ideas are welcome and thanks fmax !
Old May 9, 2003 | 01:07 PM
turbochic's Avatar
to host pics try http://www.imagestation.com/
backyardjoe
May 17, 2015 05:10 AM
CivicExMaster
Feb 26, 2008 12:20 PM
96 Ls lnTeG
Aug 10, 2003 08:46 AM
TDRacing
Sep 25, 2002 01:27 PM
