Flywheel - clutch
Old May 8, 2003 | 11:08 PM
civcexcoupeblack's Avatar
Default Flywheel - clutch
Im putting a new clutch in. Its a action 2md. Do I NEED to resurface the flywheel? What happens if I dont? It was completly cleaned by a machine shop, and inspected. I was going to have them lighten and balance and resurface it, but decided not to. Thanks
Bill
Old May 9, 2003 | 12:48 AM
ExospeedAMcrx's Avatar
Default Re: Flywheel - clutch (civcexcoupeblack)
its recommended to resurface the flywheel everytime you change your clutch. you need a fresh surface for the clutch disc to have contact to. its the same thing with changing your brakes, you need to turn the rotors so its a new flat surface for the brake pads to have good contact. these flywheel and rotor surfaces get warped or wornout.. so its possibility you arent getting a good contact between the clutch disc and flywheel.
Old May 9, 2003 | 01:35 AM
4DeepCivic's Avatar
What he said...
Ralleh
Honda S2000
11
Oct 13, 2009 05:40 AM
freakasis
25
Nov 16, 2008 05:37 AM
VtecCivic93
Mar 25, 2008 07:36 PM
IntegraMastaz
Dec 13, 2005 05:26 AM
Dirty GS-R
Feb 5, 2002 05:08 AM
