antenna problem
Old May 8, 2003 | 10:32 PM
baybeboi's Avatar
Default antenna problem
My radio doesn't have good reception so most of the time the radio just plays alot of static, when im lucky it picks up signal and plays songs clearly but only for a little bit. I also noticed that the antenna doesn't come out when i turn on the radio, how can i fix this? It seems like the antenna isn't working, what could be the problem? Car is a 99' civic ex if that helps.
Old May 8, 2003 | 10:37 PM
VXpride's Avatar
Default Re: antenna problem (baybeboi)
My radio does the same thing. Just check the antenna connection in the back of the deck... if that's not it, check the actual antenna
Old May 8, 2003 | 10:44 PM
93egbeau's Avatar
Default Re: antenna problem (VXpride)
I GOT vx and my antenna sux *** i need to make this little vx faster how should i go about it i have header intake and exhaust help me please
Old May 8, 2003 | 10:46 PM
IEATLINT's Avatar
find the wire that controls the antenna in the dash and hook it up to a switch w/ a 12V power supply. and whenever your listening to the radio flip the switch. or if your deck has a antenna control wire...hook it up to that and it should only go up when the source is the radio, and should go down when its on cd.
djtony5
Apr 2, 2005 10:47 AM
crewjones
Audio / Security / Video
May 9, 2003 09:37 PM
sonicblueteg2k
Feb 7, 2003 10:57 PM
$pecial K
Aug 27, 2002 07:17 AM
Julian
Jul 26, 2002 01:13 PM
