Ls swap in crx..............look at my slip let me know what needs to be done
Old May 8, 2003 | 05:21 PM
H23vtecEG's Avatar
Default Ls swap in crx..............look at my slip let me know what needs to be done
i went to the track last night with my friends crx that we put a b18b1 in it with a 91 Ls tranny.
R/T - .583
60 - 2.324
1/8 - 9.887
mph - 72.06
1/4 - 15.349
mph - 89.17
i mean what the F... those numbers seem bad and i got around the same time in 6 runs. the car has nothing but an intake everything else is stock including the stock SI exhaust.
are these good numbers? i know its stock as hell but i was expecting better
Old May 8, 2003 | 05:27 PM
WhiteDSM520's Avatar
Default Re: Ls swap in crx..............look at my slip let me know what needs to be done (H23vtecEG)
The LS tranny sucks , put an S1 in and you'll hit 14's. Don't expect anything good till thats replaced.
Old May 8, 2003 | 06:30 PM
iwouldHITit's Avatar
Default Re: Ls swap in crx..............look at my slip let me know what needs to be done (WhiteDSM520)
i have the same motor and run about the same time but i dont have 4th gear..i would probably hit lower ets if i had 4th gear
Old May 8, 2003 | 06:50 PM
Neukin's Avatar
Default Re: Ls swap in crx..............look at my slip let me know what needs to be done (iwouldHITit)
get a little boost on that engine... you can always sell the kit you put together plus t would be a great experience.
Old May 8, 2003 | 07:14 PM
AGPSuperstar's Avatar
that time looks normal to me
Old May 8, 2003 | 07:51 PM
desert eagle's Avatar
your timeslip was unsat for a couple reasons. the first one is non-vetc engines dont make alot of horse power na stock. if you can afford it stick a b16 vtec head on it. you will love it then. but you will need traction or kiss your first two gears goodnight. then if you stay na stick a b16 tranny on it because the gears are short as F@#$ which is a good thing for the 1320 but sh!@@# on the freeway.
Old May 8, 2003 | 08:01 PM
Blaze45's Avatar
Brrraaaap!
lower you 60 footer and get some slicks, ditch the stock headers and exh. and get a different IM and that should plant you frimly into the 14s.
Blaze
Old May 8, 2003 | 08:02 PM
Blaze45's Avatar
Brrraaaap!
O yeah whats your elevation?
That could be a big part.
Blaze
Old May 8, 2003 | 08:43 PM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23vtecEG &raquo;</TD></TR><TR><TD CLASS="quote">R/T - .583
60 - 2.324
1/8 - 9.887
mph - 72.06
1/4 - 15.349
mph - 89.17</TD></TR></TABLE>
You are complaining about running a low 15 with an LS swap that has nothing more than an intake? You should be HAPPY that your motor is as strong as it is. First fo all, get a good header and exhaust system. This alone could possible drop you into the 14s. Also, you might want to do some suspension modifications, better tires/wheels, and PRACTICE. But seriously, low 15s is not EVEN bad with your current setup.
Alot of people will also recommend a B16A transmission. If you care at all about the longevity of your motor, DON'T DO THIS! The B18A was never designed to be a revver. And your motor will not last running constant high revs on the freeway for extended periods of time. Stick with what you have.
Old May 10, 2003 | 07:24 AM
H23vtecEG's Avatar
Default Re: Ls swap in crx..............look at my slip let me know what needs to be done (StorminMatt)
i live in New Hampshire the elevation is pretty high up here
i went to the track again and i hit a 15.1 which i'm pretty happy with
you guys are right i should be happy with these times because the car is completely stock i should hit 14's once i put more money into it
Old May 10, 2003 | 07:58 AM
Ben Ogle's Avatar
I hit a 15.1@91 last weekend with my 2020lb LS civic 4 door. I couldnt get below a 2.35 60' though. I was kinda dissapointed. I'm at 2500ft btw.
Ben
Old May 10, 2003 | 09:39 AM
elmalouno's Avatar
is your crx white by any chance?
Old May 10, 2003 | 09:41 AM
H23vtecEG's Avatar
Default Re: Ls swap in crx..............look at my slip let me know what needs to be done (elmalouno)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elmalouno &raquo;</TD></TR><TR><TD CLASS="quote">is your crx white by any chance?</TD></TR></TABLE>
yeah it is. how did you know that?
Old May 10, 2003 | 10:24 AM
elmalouno's Avatar
do u also have a civic with a type R motor?
Old May 10, 2003 | 08:52 PM
brent_G's Avatar
i thnik that time is pretty good too...i had a y1 tranny on my b18a1 and loved it...but highway driving wasnt that great like they said above. Id stay wiht the ls tranny if i were you...that tranny was designed perfectly for that motor. 3rd gear was always my favorite. btw i ran a 14.9 wiht intake,and exhaust. With a 2.1 60ft. But be happy wiht that time, that motor i think is prolly the best motor to build from...you have soo many options now!
Old May 10, 2003 | 11:08 PM
giooooo's Avatar
damn i ran 15.4 @89 bone stock with my stock b18a1 2600 lbs integra
Old May 11, 2003 | 07:26 AM
H23vtecEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elmalouno &raquo;</TD></TR><TR><TD CLASS="quote">do u also have a civic with a type R motor?</TD></TR></TABLE>
yeah thats me. is this the kid that bought the type -R interior
Old May 11, 2003 | 09:42 PM
elmalouno's Avatar
nope... i got the b18a swap..
projectTeG
Dec 21, 2005 07:18 AM
JTauto
Jun 9, 2005 07:12 AM
92HB_HB
Mar 25, 2003 09:27 PM
SimonsTeg
Feb 15, 2003 07:27 AM
legendboy
Jul 28, 2002 03:41 PM
