can someone tell me what this SRS"code" mean?
Old May 8, 2003 | 05:13 PM
GSblueRacing's Avatar
Default can someone tell me what this SRS"code" mean?
The car starts as usual, everything is fine. Then as I start to drive. the SRS light blinks.
This is the sequence. I think it's either.
1 short then 1 long or
2 short blinks then 1 long one.
does anyone know what these 2 codes are?
Old May 8, 2003 | 05:30 PM
NeoGSR's Avatar
Default Re: can someone tell me what this SRS"code" mean? (GSblueRacing)
but why would the SRS button blink.....those codes where for the CEL i thought.....
SRS=saftey restraint system
airbags? seatbelts? i'm clueless on this one....bump
Old May 8, 2003 | 05:58 PM
Merlin00069's Avatar
Default Re: can someone tell me what this SRS"code" mean? (NeoGSR)
safety restraint system yes....
its the airbags captain check the srs unit under the steering wheel...might have jiggled a little , either that or take it to the dealer and tell them to check it out..i took my srs out of my car because of the jdm steering wheel i have now...so the srs light is on..i just took out the bulb for it... hope this helped..
Old May 8, 2003 | 06:41 PM
Default Re: can someone tell me what this SRS"code" mean? (Merlin00069)
maybe you are right. cause a few days ago my steering wheel was removed and put back, what could have cause this problem? cause the first time we took out the wheel it didn't happen. but this time it did,. loose connection?anyone else?
Old May 8, 2003 | 06:46 PM
Cramerox's Avatar
well you can try to take it back of and make sure its on correctly...if you really dont know take it to someone who does...you wouldnt want that thing blowing up in your face.
Old May 8, 2003 | 07:17 PM
LegoZ81's Avatar
Default Re: can someone tell me what this SRS"code" mean? (Cramerox)
SRS is supplemental restraint system it is the Airbags Have a dealer troubleshoot this. if you do stuff wrong the bag can and will deploy!
it is most likely when you removed the wheel always reference a helms manual before doing anything near the SRS system!
Once again I VERY HIGHLY recommend that you take this to the dealer.d
Believe me you don't want to get hit by one and I know...
Old May 8, 2003 | 09:19 PM
b19coupe's Avatar
If the key was on and you disconnected the driver's airbag, that will give you an SRS code. Also, if you rotated the cable reel while the steering wheel was off, and put the wheel back on, there is a chance that you damaged the cable reel. The cable reel has to be centered, it only turns so much each way, and if you go past it's limit, it fails. BTW-SRS = Supplemental Restraint System.
Old May 8, 2003 | 10:35 PM
typeRNSX's Avatar
Default Re: can someone tell me what this SRS"code" mean? (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">If the key was on and you disconnected the driver's airbag, that will give you an SRS code. Also, if you rotated the cable reel while the steering wheel was off, and put the wheel back on, there is a chance that you damaged the cable reel. The cable reel has to be centered, it only turns so much each way, and if you go past it's limit, it fails. BTW-SRS = Supplemental Restraint System. </TD></TR></TABLE>
Good job explaining just wanted to add that if the steering wheel was removed with out disconecting the battery that is another problem.
Old May 9, 2003 | 08:57 AM
NeoGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">BTW-SRS = Supplemental Restraint System. </TD></TR></TABLE>
i stand corrected
Old May 9, 2003 | 10:14 AM
IntEGNYC's Avatar
Did you say yoru SARS light was flashing?
Old May 9, 2003 | 10:23 AM
atch417's Avatar
Default Re: can someone tell me what this SRS"code" mean? (IntEGNYC)
Old May 9, 2003 | 12:12 PM
allmotorls95's Avatar
Default Re: can someone tell me what this SRS"code" mean? (atch417)
is the cable reel for the srs..
Old May 9, 2003 | 01:21 PM
b19coupe's Avatar
Default Re: can someone tell me what this SRS"code" mean? (allmotorls95)
Yes. The power for the driver's airbag comes from the cable reel. If the cable reel is damaged, you will get an SRS light.
Old May 10, 2003 | 12:03 PM
does anyone have an extra cable reel for sale? i need an obd1 from a 94/95 teg.
thanks
erck
Jun 8, 2007 07:34 PM
92ehatch
Jul 30, 2006 05:57 PM
k-series
24
Dec 29, 2003 09:25 AM
Marauder
Apr 11, 2003 03:26 PM
AmginE
Nov 13, 2002 08:04 PM
