I swapped an SI cluster into my DX and it shows my idle at 1500. How do I adjust?
Old May 8, 2003 | 05:00 PM
3 G's's Avatar
Default I swapped an SI cluster into my DX and it shows my idle at 1500. How do I adjust?
The idle speed is supposed to be around 800 RPM, right? So how do I adjust it to the proper RPM? I also want to know what the yellow plug is for. I'm guessing it's the SRS, but my car doesn't have it....could it be a different plug for the seatbelt light? Cause the seatbelt light on the "new" cluster doesn't work.
Thanks in advance, people of Honda-Tech.
Old May 8, 2003 | 05:02 PM
tominos's Avatar
Default Re: I swapped an SI cluster into my DX and it shows my idle at 1500. How do I adjust? (3 G's)
is it idling at 1500 when fully warmed up? or when you just start it up, and engine is cold? there is a screw on the throttle body to adjust the idle. wait till it warms up, if cold and see what the idle is.
Old May 8, 2003 | 05:41 PM
3 G's's Avatar
Default Re: I swapped an SI cluster into my DX and it shows my idle at 1500. How do I adjust? (tominos)
It idles at 1500 when it's cold. Is that supposed to be normal?
by the way, thanks for your only reply. It's helping out
actually, what I meant was, is the tachometer accurate?
again, thanks
Modified by 3 G's at 2:54 AM 5/9/2003
2000CX's Avatar
i am swapping a 00 SI into my 00 cx...will i have any problems with wiring?
Old May 8, 2003 | 05:42 PM
Nameless RB26's Avatar
Don't ever adjust your stock idle. Ever. (unless you need to because you are extremely modified) There's reasonable explanations for everything. Something as simple as a malfunctioning ECT sensor can cause a high idle, and you wouldn't always necessarily know it.
Is this a cluster problem or an engine problem? First you need to verify that.
And yeah.. yellow plug is SRS. (I'm pretty damn sure)
Old May 8, 2003 | 05:43 PM
Default Re: I swapped an SI cluster into my DX and it shows my idle at 1500. How do I adjust? (2000CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000CX &raquo;</TD></TR><TR><TD CLASS="quote">i am swapping a 00 SI into my 00 cx...will i have any problems with wiring?</TD></TR></TABLE>
none at all. I'm using one in my 99.
Old May 8, 2003 | 05:44 PM
mixmastabob's Avatar
yes idling at 1500 is normal when its cold. although the idle on mine was high when the engine was warm also. there is a little screw on the right/left side of the throttle body to adjust that.
Old May 8, 2003 | 05:48 PM
IWearMyKswiss's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3 G's &raquo;</TD></TR><TR><TD CLASS="quote">It idles at 1500 when it's cold. </TD></TR></TABLE>
that is normal,..dont worry about it
Old May 8, 2003 | 05:54 PM
ERA's Avatar
ERA
like someone said already.. don't adjust your idle screw. Leave it alone. If the engine sounds to be at the same idle speed as it was before the cluster swap, you need to adjust the needle on the cluster. I had to do this when converting to JDM cluster, so it's very possible you may have to do the same. Good luck.
Old May 8, 2003 | 05:57 PM
3 G's's Avatar
Default Re: I swapped an SI cluster into my DX and it shows my idle at 1500. How do I adjust? (delslo26)
Wow, this is really helpful!
Thanks a whole lot, people
I knew I joined HT for a reason
2000blksi
May 19, 2011 02:22 PM
Tyrant_007
Mar 28, 2011 08:01 PM
GsrVtec
Jul 24, 2006 10:51 PM
lv6l
14
Nov 28, 2005 06:50 PM
udm_motorsport
Mar 6, 2003 01:12 PM
