Need info on injectors
I was wondering if someone could enlighten me on which injectors from other cars could i use for my 95 gsr. I heard that dsm injectors would work. How many cc's do the stock gsr injectors run at, 220, 240? What would happen if you put 400cc injectors in a near stock gsr, i will be going full turbo soon?
stock GSR injectors run at 240 cc/min. I think 5th gen Prelude injectors will work, they are 290 cc/min. The DSM are usable from what i understand. you need the injectors, clips, resistor box, ?. I not toally sure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteinteg95 »</TD></TR><TR><TD CLASS="quote">What would happen if you put 400cc injectors in a near stock gsr, i will be going full turbo soon?</TD></TR></TABLE>
It would barely run and possibly ruin the motor.
could you tell me more about injectors. Are the stock injectors sufficient? What kind of mods could stock gsr injectors handle? Is there a difference between obd1 and obd2 injectors?
Modified by whiteinteg95 at 5:31 PM 5/9/2003
Modified by whiteinteg95 at 5:47 PM 5/9/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteinteg95 »</TD></TR><TR><TD CLASS="quote">could you tell me more about injectors. Are the stock injectors sufficient? What kind of mods could stock gsr injectors handle? Is there a difference between obd1 and obd2 injectors?</TD></TR></TABLE>
What are your plans. The stock injectora could pretty much handle most bolt-ons as well as a a basic turbo set-up. Once you go beyond that, upgraded injectors are pretty much a necessity.
