Tach problem for a B18C1 into EG Hatch..
Old May 8, 2003 | 12:23 PM
SleepyEG's Avatar
Default Tach problem for a B18C1 into EG Hatch..
I'm swapping my B18C1 into an EG hatch and there's only one problem...The tach..I was thinking of swapping my whole GS-R Gauge cluster in, but not sure how difficult that would be. I sure as hell don't want a 5" monster tach.. Any suggestions?
~james
Old May 8, 2003 | 12:40 PM
YumVTEC's Avatar
Default Re: Tach problem for a B18C1 into EG Hatch.. (IcrashedmyGSR)
get an Si or an Ex cluster. they plug right in and have a factory tach. you can use the gs-r cluster but have to re-wire the snot out of the cluster plugs.
Old May 8, 2003 | 01:29 PM
SleepyEG's Avatar
Default Re: Tach problem for a B18C1 into EG Hatch.. (YumVTEC)
cool thanks,
any ideas where I can get a stock Si cluster??
~james
Old May 8, 2003 | 01:43 PM
poison's Avatar
classifieds forum, eBay, junkyards..
Old May 8, 2003 | 02:21 PM
DesiDez's Avatar
Default Re: Tach problem for a B18C1 into EG Hatch.. (poison)
yeah, i bought my si cluster off someone here. plugs right in
Old May 9, 2003 | 05:02 AM
VTECVillain's Avatar
A 92-95 EX/Si cluster will be a direct bolt in with no wiring or modifications. The GSR cluster will not bolt in and must be modded to work which usually looks pretty ghetto. The plugs are different and the pins can't be repinned from one plug to the other since they are a different size. You would also need the GSR plugs with some wire then splice them into your existing chassis wiring
crazy_ls_90
Jul 2, 2008 12:50 PM
crxcel
Apr 23, 2007 08:30 PM
msinsky14
12
Mar 1, 2006 07:36 PM
fast90hatch
Dec 19, 2004 07:23 AM
Chicano
Sep 14, 2004 07:11 PM
