GSR or Si Cluster in EG?
I have a 93 civic sedan, and i was wondering if you can put a GSR or SI Gauge Cluster in it with out changing the whole dash??? And are the plugs the same???
thanks
thanks
yeah search... and then go to the FAQ at the top of this forum...
you can put it in, needs modification to the gauge bezel, no the plugs are not the same, and you will need to cut your stock plugs and rewire the GSR or Si plugs to the wires in your car... and to bolt the cluster down, i believe you must break some tabs off and mount the cluster farther back in the cluster area...
i did this to my old car, and i dont think i would want to do it again.. also another good way to do this is grind the top of the GSR cluster off and use the EG cluster cover then you wont have any space between the bezel and the cluster
