Ram-Air intake helpful?
Old Jul 6, 2001 | 10:17 AM
HX_Guy's Avatar
Default Ram-Air intake helpful?
I saw a conversation going on on another board about this.
Basically, does running a setup where the filter is being hit by direct air help vs a standard cold air intake?
This would be hard to dyno test, however with a manifold pressure sensor I think it would be possible.
If, with a regular cold air setup, at WOT the manifold pressure is -50 mmHg...then if a ram-air setup is used..the pressure reads
-20 mmHg (or how about + 05 mmHg...haha yea right...boost from an intake ) then the ram-air would actually be helping.
Thoughts? Comments? Experiances?
[Modified by HX_Guy, 11:20 AM 7/6/2001]
Old Jul 6, 2001 | 10:23 AM
len's Avatar
len
Default Re: Ram-Air intake helpful? (HX_Guy)
Theoretically, having a filter element open to the atmosphere will probably yield a performance increase. But how will you pull that off? Drive with the hood off?
As long as it gets direct stream of cold air it's always going to be a little bit better than a system that draws air from underneath and behind a bumper. Remember cold air equals denser air equals need more fuel.
Old Jul 6, 2001 | 10:30 AM
HX_Guy's Avatar
Default Re: Ram-Air intake helpful? (ILOVERACING)
I was refering to something like a front mount intake system (which I know looks dumb...but if it works?)
Or possibely removing the headlight (for the track only of course)
Old Jul 6, 2001 | 10:39 AM
len's Avatar
len
well basically any setup where you have direct air running to the filter will be an improvement. A substantial improvement? I doubt it, but every little bit helps when your on the track. I've seen alot of track guys remove their corner lights and even headlight assemblies for racing usage.
But I question the practicality of the front mount intake system on the street. my 0.02
Old Jul 6, 2001 | 01:11 PM
H23 Power's Avatar
I remove my corner light at the track...but sometimes i question if the air getting in there is worth the sacrifise in aerodynamics....I've tried both ways...its hard to tell a difference because I haven't gotten super consistent in this car yet.
JuneBugDrfter
Apr 12, 2013 06:46 AM
Ryanhooligans
Sep 13, 2006 11:25 AM
MadCityLude
Aug 31, 2006 06:56 AM
crooked muffler
May 21, 2003 02:57 PM
