need help with seat belt conversion
doesn anyone have any pics of some seat belt conversions in any CRXs...i jsut got some new door panels and i need to convert the seat belt motor to my pillar, but i don't really have any ideas...if any could give there advice, it woul dbe much appreciated.
Sounds like your messing with your safety equipment..
If any thing pull the seatbelts comletely out.. but only after you put in a 4,5 or 6 point harness (depending on how Down your are)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane »</TD></TR><TR><TD CLASS="quote">
If any thing pull the seatbelts comletely out.. but only after you put in a 4,5 or 6 point harness (depending on how Down your are)</TD></TR></TABLE>
What do you mean...4,5, or 6 point harness?
A full Race harness, the number of points is the number of attachment points to the frame of the car..
you can get a 3 point too..
they have a small selection at optauto.com you can check out..
I get a discount through them...
most of the stuf to put the piller mounted seat belts are still there. the hole in the piller is still there but you have to weld a bolt there to bolt it in to. the mounting points on the sides for the car are already there too, and it will be missing the bolt to hold down the clip part on one of the sides. you'll have to weld another bolt down for that, but the other one is there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evilxkid »</TD></TR><TR><TD CLASS="quote">most of the stuf to put the piller mounted seat belts are still there. the hole in the piller is still there but you have to weld a bolt there to bolt it in to. the mounting points on the sides for the car are already there too, and it will be missing the bolt to hold down the clip part on one of the sides. you'll have to weld another bolt down for that, but the other one is there.
Some good info..
</TD></TR></TABLE>Some good info..
EKB18BPR3
Dec 18, 2006 05:50 PM
JustHere4ADay
25
Sep 26, 2004 01:13 PM
fastball777
Jun 23, 2004 12:52 PM
