oil in coolant
Old May 8, 2003 | 06:38 AM
turbomike's Avatar
Default oil in coolant
99 accord with 2.3 vtech. got oil in the coolant. replaced rad and pulled head and had it check at machine shop. Went back with OEM honda parts...still same problem. Any ideas of where else to look??
Old May 8, 2003 | 07:00 AM
mr98accord's Avatar
Default Re: oil in coolant (turbomike)
Did U check the block?If U did the radiator and head,the block is the other part butdo U have water in your oil as well?
Old May 8, 2003 | 08:02 AM
urbanlegend21's Avatar
New User
Default Re: oil in coolant (mr98accord)
did you replace the head gasket?
Old May 8, 2003 | 08:49 AM
Stew Pidasso's Avatar
Default Re: oil in coolant (urbanlegend21)
That's definite headgasket symptom... Were the head bolts torqued properly? Was the head checked for warpage? Was the block checked for an uneven surface?
Old May 8, 2003 | 01:36 PM
95sihb's Avatar
Default Re: oil in coolant (Stew Pidasso)
if it's not the gasket........... there has to be a crack in there somewhere
Old May 8, 2003 | 07:54 PM
jweller's Avatar
Default Re: oil in coolant (96accordex)
blown headgasket
Old Jan 19, 2010 | 12:16 PM
MOBILETECH's Avatar
New User
I'M HAVING THE SAME PROBLEM, REPLACED THE HEAD GASKET MACHINE SHOP SAID HEAD WAS OK TORQUED BOLTS DOWN TO SPECS. PER ALLDATA. TWO MONTHS LATER SAME PROBLEM REOCCURED. PLEASE HELP THIS IS 98 ACCORD 2.3 LITER
Old Jan 19, 2010 | 02:57 PM
nus_dogg's Avatar
Cracked Intake Manifold, crack head, headgasket, and there's some more that I learned in class but I'll name some more when I get home.
Old Jan 19, 2010 | 08:27 PM
AccordVT's Avatar
I'm assuming you used an OEM Honda head gasket? Did you follow the tightening sequence? Did you re-use the head bolts? If your certain the head gasket job was done correctly, I would start looking for cracks as others have said.
Hondapreludeg
Aug 24, 2010 12:51 PM
Dj^BaNNeD
May 19, 2007 02:02 PM
BluLude
Jul 22, 2005 06:20 AM
preludeguy_92
May 23, 2005 06:39 PM
turbomike
May 8, 2003 07:26 AM
