gsr crank threads for flywheel bolts kinda stripped
Old May 7, 2003 | 09:30 PM
I-VTECRX's Avatar
Default gsr crank threads for flywheel bolts kinda stripped
well i just purchased a 95 gsr block and i was pulling out the flywheel bolts so i can take out the crank, and the f__ken bolts stripped so im just wondering if anyone had experience with this, because i was just gonna take my crank to benson and see what he can do. the flywheel is already off but the threads some are good some are ok and it looks like i cant use a tap set on it because it looks to short not unless anyone knows where i can get a tap that short so i can fit it into the crank threads
Old May 7, 2003 | 09:35 PM
.RJ's Avatar
.RJ
Default Re: gsr crank threads for flywheel bolts kinda stripped (EF8hYbRid)
did you use a 12-pt socket?
Old May 7, 2003 | 09:47 PM
I-VTECRX's Avatar
Default Re: gsr crank threads for flywheel bolts kinda stripped (.RJ)
i used a 12pt socket the threads on the crank stripped
Old May 7, 2003 | 10:54 PM
b19coupe's Avatar
Dan might be able to clean up the threads for you if they are not too hacked. If not, get a new crank.
Primo Gen
Feb 20, 2016 05:55 PM
earl
Oct 8, 2006 06:53 AM
LSEGHATCH
22
Jun 28, 2006 11:08 AM
Blueallie
Jan 2, 2005 02:47 PM
Silude
Jun 6, 2001 07:24 PM
