knockin at high rpm h23a
Old May 7, 2003 | 06:17 PM
gulf imports
Guest
Posts: n/a
Default knockin at high rpm h23a
i got a 94 si today its knockin at about 4 thow rpm it not lound knockin i dont know what it is?? yall know? or what do i do? i changed the plugs wires an plugs! what to do>?
Old May 7, 2003 | 06:36 PM
sslude's Avatar
Default Re: knockin at high rpm h23a (gulf imports)
maybe a rod or spun a bearing.
Old May 7, 2003 | 09:22 PM
93ludeSi's Avatar
have you messed with the spark timming, it could be spark knock
Old May 7, 2003 | 11:49 PM
gulf imports
Guest
Posts: n/a
Default Re: (93ludeSi)
how would i find out that!
Old May 8, 2003 | 12:41 AM
blueheavenbuddha's Avatar
Default Re: (gulf imports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gulf imports &raquo;</TD></TR><TR><TD CLASS="quote">how would i find out that!</TD></TR></TABLE>
how would i find that out?
Old May 8, 2003 | 07:47 AM
BoostedH23a1's Avatar
Default Re: (blueheavenbuddha)
better hope its not a bearing... did u get shitty gas? maybe its something simple like that.. u can pull your oil pan to check bearings... maybe if it spun one bad when u drain your oil u will see metal flakes... thats rebuild time..
Old May 8, 2003 | 08:41 AM
JTCdudeman's Avatar
Master H Technician
Default Re: (BoostedH23a1)
you bought it knowing there was a chance of having a serious problem with it right off? Hope it was a steal... It could even be your timing being to far advanced... Check the easy stuff first or take it in to a shop and they can since you just got it...
Old May 14, 2003 | 09:15 PM
gulf imports
Guest
Posts: n/a
Default Re: (JTCdudeman)
i put new clutch in it was so much a bitch it was not even funny we cranked it up! it was still knocking i got 2 new cv joints clutch = 500 dollers maskat *** ***! i think it is a spun bering *** *** im going to find out tomarrow - aka im a car dealer tryin to start buyin a selling cars im loseing on this *** in car -nick
Old May 14, 2003 | 10:10 PM
Que_Lude's Avatar
Yeah, don't put Arco in there You should be running at least 91 octane
Old May 15, 2003 | 08:37 AM
92LudeSR's Avatar
Is it a loud knock or more of a buzzing knock sound? I had a downpipe and both pipes were broken inside just below the connection to the manifold. It wasn't visible from the outside and made kind of a knocking sound as well.
Old May 15, 2003 | 08:40 PM
gulf imports
Guest
Posts: n/a
today im going to find out its only at high rmps that is makes a knockin its sonds like a spun bernin
JDM-EJ1
Aug 14, 2005 12:33 PM
b0wti
May 24, 2005 03:12 PM
rainmanef
Apr 8, 2004 09:38 PM
Prelussion
Mar 26, 2002 05:36 AM
