how to install new SI dizzy??
Old May 7, 2003 | 06:13 PM
AGPSuperstar's Avatar
Default how to install new SI dizzy??
are there any instructions you guys can show me to follow on installing it on my dx crx? thanks
Old May 7, 2003 | 06:17 PM
ScottEK's Avatar
Default Re: how to install new SI dizzy?? (AGPSuperstar)
Mark your spark plug wires, which one goes where. Pull them out.
Some people put the engine at top dead center, I dont. Take out the 3 12mm bolts, pull the distributor off. Put the new distributor in it's place, it will only go on one way.
EDIT: Get a hold of a timing light and set your timing after replacement.
Old May 7, 2003 | 06:19 PM
Default Re: how to install new SI dizzy?? (beta13)
do i have to put it in TDC?? thats the part i dont really understand
Old May 7, 2003 | 06:26 PM
FourthGenHatch's Avatar
You don't need to put it to TDC, it only goes one one way, you can't do it wrong.
Old May 7, 2003 | 06:28 PM
Default Re: how to install new SI dizzy?? (FourthGenHatch)
so i just take off the old one and put on a new one?? well anyways....i need some of you guys to post pics of your plug because all my wires are faded and i cant tell which is which any more....thanks agp
Old May 7, 2003 | 07:26 PM
anyone??
Old May 7, 2003 | 07:33 PM
hahahahhah's Avatar
just mark which wires go where... with different color chalk or something..
Old May 8, 2003 | 04:38 AM
white99gsr's Avatar
Default Re: how to install new SI dizzy?? (CR1X)
first of all there are only two plugs and you can't get them mixed up, and they only go on one way, so you cant screw that up. just take the old one off and put the new one on.
Edit: your putting it on a DX? what motor do you have? you may have to modify the dog ears and run two more wires for the Crank Angle Sensor.
meallout
Mar 19, 2009 11:34 AM
krazyteg
Apr 11, 2006 02:55 PM
93H22Lude
Oct 13, 2005 01:22 PM
dajusta
Sep 28, 2004 07:11 PM
viet4gvtec
Apr 20, 2003 08:50 PM
