My climate control is stuck in the heat position and im roasting here!
Old Jul 6, 2001 | 01:03 AM
integra0260's Avatar
New User
Default My climate control is stuck in the heat position and im roasting here!
1995 acura integra. The climate control is stuck on heat, the furthest it moves to cool is halfway and thats it! I've tried WD40, but to no avail. How do I take this thing apart or are there any other suggestions? Thanks for your help
Old Jul 6, 2001 | 03:59 AM
CardDealer's Avatar
Banned
Default Re: My climate control is stuck in the heat position and im roasting here! (integra0260)
Modified by CardDealer at 4:13 AM 11/16/2006
Old Jul 6, 2001 | 06:26 AM
D's Avatar
D
check the cable linkage between the back side of the lever and the actuator under the dash. you'll have to remvove the armrest, and center console.
cable is in a plastic housing and clipped in place. you can adjust the clip in location.
HTH
D
Old Jul 6, 2001 | 09:34 AM
JinMTVT's Avatar
New User
Default Re: My climate control is stuck in the heat position and im roasting here! (D)
under the intake maifold..there are the heater tubbings and the on/off valve u are opening and closing with the heat/cold setting..
it usually jams there..
follow the wire and check out if ur wire between the engine room to the heater control bok ( the white one under the dash )
is not jammed in itself..if not then check out by hand if u can turn off or on the heater valve on the tubbing..try wd40 there.. ;p
good luck
navin
Dec 16, 2007 10:04 PM
chitownrida
Feb 22, 2007 12:38 PM
hpsi93
Nov 3, 2005 07:34 AM
MassScene
Jul 26, 2005 06:43 AM
eric712
Jun 9, 2002 07:20 PM
